928 Forum 1978-1995
Sponsored by: 928 Specialists
722.3 Transmission Shift Rod Seal Replacement
Old Mar 14, 2023 | 06:45 PM
khalloudy's Avatar
khalloudy
Default 722.3 Transmission Shift Rod Seal Replacement
Hi All,
During my service, we noticed that there is a slight ATF seeping behind the transmission neutral safety switch which indicates that the seal for the shift rod is probably not sealing well anymore. I was wondering if the rod can be removed with the transmission in the car.
Old Mar 15, 2023 | 06:56 AM
skpyle's Avatar
skpyle
Hi khalloudy!
I did this job with the transmission upside down on my work bench. I believe it can be done with the transmission in the car. Pan has to come off, filter and complete valve body come off.
Here it is, upside down.
Selector shaft circled in green.
Getting the shaft out to replace the seal is fiddly work, but quite doable.
Good Luck!
Old Mar 15, 2023 | 07:07 AM
Schocki's Avatar
Schocki
Should be possible during an ATF change.
Old Mar 15, 2023 | 06:49 PM
khalloudy's Avatar
khalloudy
Originally Posted by skpyle
Hi khalloudy!
Good Luck!
I am sure it is a million times easier on a workbench but dropping the transmission is not an option for now… until I do a larger job planned down the road. the pic you provided is great as it will help me plan and navigate the work.
Originally Posted by Schocki
Schoki, yes this video gave me the inspiration as initially I though this would be a full on drop out of the car but it seems the rod might be short enough and if we move the heat shield on the left side far enough, might give us just enough wiggle room. Hope it works
Old Mar 15, 2023 | 07:15 PM
Zirconocene's Avatar
Zirconocene
Slightly off topic, but having spent some time staring at a different valve body on a different Porsche, they remain very little short of black magic to me.
Good luck with the repair, I'm interested to see how it goes for you as I'm sure I'll have to do this myself, some time in the future.
Cheers
Old Mar 15, 2023 | 11:14 PM
skpyle's Avatar
skpyle
khalloudy, I never suggested you drop the transmission. I was just showing you that I did it for perspective. And since all the parts are inside the case, you should be able to do it with the transmission in the car.
Drop the pan, drop the filter, drop the complete valve body, and you then have access to the selector shaft.
Good Luck!
Old Mar 16, 2023 | 07:37 PM
khalloudy's Avatar
khalloudy
Seth,
Yes I totally got it… just saying you were lucky to have the transmission out as many tidying up could be done on the bench. I hope this reduces more the number of parasitic leaks I have… kinda got them to a minimum now
