What mounts to this bracket?
There is a bracket on the passenger side of the engine which the air pump change over valve mounts to with two bolts. In addition to this mount, there is a single 90 bent part with a nut welded to it. I cannot find anything that would mount to this. Does anyone know?
Under the Lift
Originally posted by Scott M.
Your not refereing to the lifting bracket on the front of the pass. cam are you? It has a nut welded onto it.
