Anyone have some extra air intake tubes that would fit my s4?
Goodness..I sure hope you find some used...ugh
https://www.porschemarinparts.com/oe...ct-92811027204
I believe I have a spare set that I can sell to you. I’ll check and let you know.
Speedtoys (10-24-2022)
Team Owner
you can buy a brand new set from parts geek for about 145.00 each,
They should last 19 years or more
Team Owner
someone was using Mercedes Benz tubes and connecting them with silicone couplers,
all you had to do was drill the hole for the cam tower port
Roger used to sell a set using the MB intake tubes. I have a couple of the intake tubes left over from some dumb shopping I did, but not a full set for what you'd need. If I can find them I'd be happy to send you what I have.
Cheers
Cheers
thanks. I will see what I can come up with regarding the Mercedes setup.
Amazon has the URO part (probably same as what Parts Geek has) for $124. What's weird is that I saw it listed on eBay as fitting '78-'91, which I was pretty sure wasn't correct. Amazon carves out '85-'86, which sucks because that's what I need (mine are carefully fitted together and wedged into place but immediately fall to pieces if I remove the strut tower bar or anything else holding it in). I'm guessing there are no good options for the S3s?
