1987 clutch slave cylinder-best option?
Hey folks, so I went to drive my '87 928 today, and the clutch pedal went to the floor. I noticed a thin streak of hydraulic fluid on the garage floor-didnt look like enough to fully disengage a clutch, but hey, here I am. Are the cheaper 100-150 options for slave cylinder replacement gone, and I gotta bite the bullet on the 450-ish option? Also, while I'm doing the job, is there more that is suggested to replace? It looks like the MC is a PITA to replace, but can maybe be rebuilt without removal? Thanks for any tips!
Team Owner
best bet collect all the parts and replace the whole system,
also get a Greg Brown flex line from the sway bar mount to the slave,
NOTE this makes bleeding a snap with minimum fluid loss.
I bought one of the last slave cylinders and it was 350.00 that was a few years ago.
NOTE dont get the 86 and earlier slave as its shorter and will wear out the new single disc
NOTE post 36 has a picture of the correct slave
https://rennlist.com/forums/928-foru...in-my-lap.html
RennHarry (10-01-2022)
I just went through this process myself, funny that now I seem to be seeing more of these happen.. But maybe it's just because I went through it 2 weeks ago.
I ended up replacing everything, figured if the slave was going then the master is probably not far behind, after all these cars are beginning to age and rubber seals and o-rings are failing right along. Peace of mind if nothing else and the master is less than $200.
Now on to the the brake master as I am sure it's in the same state.. hmm how about the calipers, and ... and .... and....![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
GregBBRD (09-30-2022)
Former Sponsor
NickTucker (10-02-2022)
Basic Sponsor
DO NOT hesitate, DO NOT pass GO just grab that one from Mark.
None out there at all apart from Porsche at $588.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Archive Gatekeeper
Roger, you've missed a golden opportunity to remind our community that Rogerboxes are unencumbered by all of this clutch hydraulics jiggery-pokery.
ROG100 (10-03-2022)
Former Sponsor
$588 clutch slaves.
T/O bearings for '87-'95 on backorder.
Pressure plate and clutch disc ~3K, these days?
Seems like someone should come up with a bulletproof substitute clutch assembly, replacing everything....
