928 Forum 1978-1995
Sponsored by: 928 Specialists
Good Radio Replacement
Old 07-12-2022 | 09:52 PM
Pete in DC's Avatar
Pete in DC
Originally Posted by WestInc
I would go with something like this one... The new Bremen with Bluetooth, usb, sd-card etc. It looks the part and won't disturb the overall look of your interior. I really like that they have hidden the connections under the "cassette-lid". It costs a few bucks of course but it is hard to beat with the nice retro look. Here's an example installed in a classic car...
I agree. P.O. @avalon68 installed this model in the 89 I bought from him (with Audisons all around) and it's very good. Don't know if it would fit the '79 aperture without Dremeling, the power draw etc, however.
Old 07-13-2022 | 11:07 AM
Quaz's Avatar
Quaz
I did the amazon head unit and it actually looks pretty decent.
The following 2 users liked this post by Quaz:
Petza914 (07-13-2022), streetsnake (07-13-2022)
Old 07-13-2022 | 12:16 PM
jesse7flying's Avatar
jesse7flying
Sorry, I didn't take any pics of my install. In my '91 S4, some previous owner had pulled the original radio and installed an Alpine head unit that was supposed to work with cutting edge Apple technology like the iPod. No Bluetooth. I popped the trim bezel off the unit, pulled it and it's cage out of the car and disconnected the tangle of wires. I used one of the Schoche adapter wiring harnesses, but I don't remember which one. If you look on the Crutchfield website, you should be able to find a suitable one. I also bypassed the amplifier and ran new wires from the head unit to the area of the amplifier and tied into the existing speaker wires, again using Schoche adapters. I did not cut any of the existing wires and I tried to disturb things as little as possible. Admittedly, sound quality is not great, but then again, it's better than what was in there and I have more capability than before. Bluetooth hands free calling, tunes off my phone and USB memory stick input are real plusses. Hope that helps. Remember, my car is a '91 so YMMV.
Jesse
Old 07-13-2022 | 03:20 PM
Chuck Schreiber's Avatar
Chuck Schreiber
Would love to install this if it fit. Looks great and I think goes with "BLAUPUNKT" theme of car whether it's a 78 or a 95.
Question remains, would it fit the narrow opening of the 78-79 trim.
Old 07-13-2022 | 03:21 PM
Chuck Schreiber
This looks pretty good, but NO way it'll fit a 78-79 without some surgery on the side trim..
Old 07-14-2022 | 08:17 AM
Darklands's Avatar
Darklands
I have the Blaupunkt also and I don't think it's worth 350 €.
From the Equipment every Kenwood or the Conti is doing the same for 150 €.
streetsnake (07-14-2022)
Old 07-14-2022 | 10:11 PM
streetsnake's Avatar
streetsnake
Default Frame Needed for Original Radio too
Can I get some direction on tracking down a frame for my original radio as well? There are a couple on eBay but I don’t believe they are correct for my ‘79. Thoughts?
Old 07-14-2022 | 11:32 PM
Alan's Avatar
Alan
Electron Wrangler
Originally Posted by streetsnake
No that's not the connector you need.
I believe you need one like THIS STYLE
Alan
The following 2 users liked this post by Alan:
Mrmerlin (01-14-2024), streetsnake (07-14-2022)
Old 01-13-2024 | 12:30 AM
928Collector's Avatar
928Collector
Default 1982 (early series) 928 shorter radio size?
I recently purchased a factory period correct Blaukpunkt radio/cassette player that was taken out of S4/GT/GTS.
Unless i'm doing something wrong It is too long to fit into my 1982 928 (base/auto).
The original radio in my 1982 had the same width face plate but was more like these shorter radios(see below).
I dont think i'm doing anything wrong with the attempted and failed installation of the Blaupunkt.
Anyone have any thoughts?
Anyone have the measurements of what radios fits in a 1978-1982 928?
Old 01-13-2024 | 03:36 AM
freakngeek's Avatar
freakngeek
Luckily for you I'm working on my '82 Auto
Here's pretty well max length of Radio you can fit, 175mm (can't quite see with angle of photo
I doubt you'll get anything longer in there
You may hit the Seatbelt relay which is also back here, removed mine as car has S4 seats and no swtich in buckle, so may need moving elsewhere
Old 01-13-2024 | 08:48 AM
928Collector
Thanks. I have 175mm as 6.89 inches.
the radio i pulled out was just over 5 inches long.
Did your 175mm radio fit into your 1982 928 ?
Old 01-13-2024 | 02:04 PM
freakngeek's Avatar
freakngeek
First picture is it sitting in, the thing below it is the warning light to give scale
It backs almost onto the pneunatic solenoids that control the vents
The cradle old radio came in not holding things back ?
Old 01-14-2024 | 03:48 AM
Darklands's Avatar
Darklands
The new head units without cd are only 100 mm deep.
davek9 (01-14-2024)
Old 01-14-2024 | 10:42 AM
Chuck Schreiber
Freak,
Do you have a pic of the front of the unit? Looks like an old school silver faced unit??
Thx!
Old 01-14-2024 | 10:53 AM
Chuck Schreiber
So here’s the issue w trying to install radios in late vs early cars. There are 2 dimensions of DIN style radios. I had a Sony unit in my GTS with trim around it and it fit fine.
The same radio would not fit in my 79. You’ve got to find a radio that is narrow and you can take the trim off it for the early cars as there is no side to side “cut out” in the trim.
Here’s what I mean. Below are the 2 Continental radios that most get. One with CD, one without. The one without will fit a later car, but you’ve got to put the trim plate on it to take up the space. The CD version will NOT fit an early car even without the trim plate, unless. You trim out the surround like this below.
Quick Reply: Good Radio Replacement
