On the back of the engine there is a tube running from one cylinder head to the other cylinder head. It's name is "air tube" 92811313503" Illustration 108-00 See picture I stole on FLICKR. I cannot imagine that it really is an air tube. There must be cooling liquid running through it. Can somebody explain?
The air tube connected to the air pump via a valve for emissions?
Sorry for my misunderstanding. If this is an air tube, why is it connected to the waterside of the cylinderhead. I appears to me that the tube is a cooling liquid connection between the cylinderheads, no water running through it. The checkvalve at the right side appears to block liquid going out but allow air coming in. Can anyone confirm this?
It doesn't connect to the water passages. The drilling goes from that back connection right through to the front where it's fitted with a threaded plug. At each exhaust port there's a small drilling from the port to that front to back air passage. The first pic is looking down the air passage, and you can see the light from a torch through from the nearest exhaust port drilling.
Air passage from rear to front. Light coming from exhaust port drilling.
Then why would they call it an 'air tube'?
Even the drawings show it works with only air...the page is called 'air injection'..
If you look closely, maybe zoom in, you can see that the cold start injector gets input fuel from rail. It injects fuel into that air tube, see the mating flanges?
In Hacker's picture, the flange that accepts the cold start injector has two allen head screws sticking out of it.
So, to eliminate the air tube seems, unless I'm missing something, to require eliminating cold start methodology. Make sense?
To be clear, starting at post #10, the L-jet discussion above is for '80-84. Ad0911's motor, if I remember correctly, is for his '79. CIS, not L-jet, so none of this cold start discussion applies.
From the 1979 service info guide RE: secondary air injection:
