928 Forum 1978-1995
Sponsored by: 928 Specialists
One advantage to the PK Tensioner (aka Porkensioner)
Old 05-15-2022, 01:50 PM
Bulvot
Bulvot's Avatar
Default One advantage to the PK Tensioner (aka Porkensioner)
Since I had my 928's belly pans off I figured I would check out how the PK Tensioner is doing. From below, it is very easy to check the extension of the piston using hex keys (allen wenches) as feeler gauges. Very quick and easy.
Using a borescope with a side camera, you can also closely inspect the piston end of the tensioner for any leaks or problems.
Compared to the process for checking the tension on a stock tensioner, the PK Tensioner is much much easier and faster.
PorKen (05-15-2022)
Old 05-15-2022, 02:16 PM
Adamant1971
Adamant1971's Avatar
Thanks for the tip as I want to check my extension before going to SITM.
Old 05-15-2022, 03:26 PM
mj1pate
mj1pate's Avatar
That is a good tip.
Theoretically the stock tensioner is reset once at about 1k mikes after install and you’re done. But there are intense threads on this that are best revisited with great caution
The following 2 users liked this post by mj1pate:
bureau13 (05-15-2022), Koenig-Specials 928 (05-16-2022)
Old 05-15-2022, 07:17 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,465 Likes on 1,462 Posts
Yeah, removing that stock timing cover to check the belt tension with a stock tensioner is a long, tedious job.
And getting the engine cool takes a bunch of skill, too.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Quick Reply: One advantage to the PK Tensioner (aka Porkensioner)
