High oil pressure on cold start?
So I changed my oil this week, and while I was at it, I swapped out the oil pressure sending unit, and put in a rebuilt alternator. My oil pressure would peg at max upon cold start, and only come down to ~4 at idle once fully warm(still would pin to 5 with any throttle action). I assumed it was a bad unit, but with the new one in, I get the same exact behavior. Any thoughts? Worry, or not worry? Thanks for any tips.
It will always be at 5 for a period of time. So I would drive it for 15-20 minutes and see then. There are many posts about high oil pressure at start-up me being one of them. Do a searh on the high oil pressure subject. https://rennlist.com/forums/928-foru...e-to-high.html
IIRC correctly the internal relief valve opens at 8 bar, so the gauge Porsche fitted isn't really appropriate.
It's telling you that the oil pressure is above 5 bar cold at idle (which it clearly is), and is nothing to be concerned about.
I believe there's a section in the owner's guide about what oil pressures you should expect to see on the gauge at various engine temperatures and revs.
davek9 (04-04-2022)
Exactly what you want it to do if running the right 15/50 or 20/50 oil. Fully warmed up at idle will still be in the middle of the gauge.
Speedtoys (04-02-2022)
