Oil Pressure to high???
So I did an oil change when I replaced the oil pan gasket on my 87 928 s4 and now I see that the oil pressure gauge is reading 5. Could I have done something when I removed the pan? I know that the rubber boot on the oil level supply switch cracked. Will have to search for an adequate replacement. the oil I put in Mobile 1 w15-50. Should I worry about the oil pressure?
yes, sounds like a simple oil sender issue. Check the wiring underneath at the sender. something may have come off (different sizes so not easy to put them on the wrong stud). The sender itself can go bad. Quick and dirty and cheap fix. That's probably all it is.
Thanks guys, I will check to see if I pulled the wire off or something. I know that it worked before I put in the motor mounts, pan gasket and rebuilt the steering rack, pulled alternator and replaced crush washers on the steering pump. I must have done something. If the wires/plug were off would it read 5?
Well, what does it read with the key on, but the engine off?
What does it read at idle when hot?
It will run 5 bar all the time (pegged high) when cold, and when much above idle (above 2000 RPM?) when hot.
Hey Joe, with the key on it reads "0". When I start it "5". to be honest, I've never really gotten it up to temperature because I just recently purchased it and trailered it home. Been up on stands since then. Will have to check it out. Although, when I purchased it the oil gauge was registering around "3" when at an idle.
Geo, welcome. I had the same concern as I drove my 928 home from the auction. But no worries. You might be able to get the number down, though, if you park it near the front door of the Rongovian Embassy for a few hours. :0 (Dryden boy here.)
Brad
Brad
You can call me Otis
^ agree, ... Also, synthetics leak out.
I run 20 50 dino, oil pressure retains 5bar during extended driving in ++90 degree ambient temps, after a few hundred miles it sometimes drops to 3bar when at idle.
If I may add, I believe 5bar may help against TBF.
viscosity is the cushion, that prevents the crank pushin'.
Otis out!
Otis out!
