The guys who did my countach barnfind are tackling a 928
#46
Wow! Stunning. Color is everything!
#48
Good luck! She's a beaut.
Cheers
Cheers
#49
Administrator - "Tyson"
More like I don't like the fact that you felt the need to act like an elitist snob and correct him for using the wrong "drop" instead of "pull".
We all know what he meant.
Kibort isn't even that bad.
Re-read your own post which was shaming someone for suggesting the engine to be "dropped"
"First, it’s not a 911. You don’t “drop” the engine. You “pull” the engine "
I've done it both ways. When the job warrants it, dropping it is much easier and faster.
This upcoming winter I plan to drop the engine from my 87. You're welcome to come over and see how it's done.
#50
not sure what this is 9n reference to but I intend to “drop” the engine / torque tube ‘ transaxle in my 78 as soon as my mechanic has the space to do so.
#51
Received 1,644 Likes
Your reaction to my post is about *you* and not about what I wrote. You reading my post and deciding that I was “shaming” is a reflection of your personal dislike of me.
#52
However, if it’s just the engine, then is is faster and cheaper to follow the WSM procedure and pull the engine.
#53
Received 5,410 Likes
#54
The aluminium body shows its benefits. If this had been a BMW, Mercedes or Jag from the same era, it would have been rusted to pieces.
#55
FYI, while the Ammo YouTube videos are entertaining, his work in person, at least on my car, leaves a bit to be desired. The countach us running now, it’s probably got another month or so before it’s drivable after which a local detailer will go over the car again.
RennHarry (04-30-2022)
#56
Lol, that guy is his own biggest fan I think ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Cheers
Cheers
