S4 injector options
Hi there. I am looking to either find a spare few stock injectors so that I can send 8 out for service or change all 8 out. The car is an 89 and I see it was previously chipped. Looking for options.
'If it was "chipped" first thing you need to know is what size injectors the chipset allowed for.
If you are going for new injectors better to get a set from the likes of Roger at http://928srus.com or one of our other parts specialists so you know they are genuiine items.
Alternatively you can go to the likes of 928 International if you want a set of 2nd hand ones. Anything off ebay is a crapshoot as some have found out to their cost the hard way. You may also get offers from listers.
As Fred indicated; since the car was modified you should find out if they upgraded the injectors. Hopefully you can figure out who made the chips and if they recommended a change from the stock 19lb. If not maybe upgrade to a 24lb one.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
0280155710 (Ford Explorer and Mustang 5.0 Fox Bodies)
210 cc @ 3 bar
DESIGN III
Perfect modern cross reference for the factory 19lb injectors on a 928 S4.
you will need Design 3 o-rings. Talk to Roger Tyson.
210 cc @ 3 bar
DESIGN III
