Squealing TB New
Replacing my TB and old tensioner with new gates and PorKen tensioner. Replacing old style tensioner. Belt will squeal when giving it throttle I have all other belts off to eliminate those.
I have 4.02 mm for the pin measurement on the PrKen and the roller is spinning for I left off the bottom cover to watch the gears and rollers.
I had changed the WP 1000 miles ago.
So was wondering if anyone out has seen this problem?
Former Sponsor
Can you isolate where the squeal comes from?
Water pump or tensioner roller are the only smooth surfaces that would slip.
Everything else is a toothed gear and can't slip....
Will verify after I put it on right.
Back to putting that belt back on!!!
