Powerless GT, Hall Sensor? or not? What else?
#91
This has been a great thread ! I was betting on some sort of air intake or exhaust restriction/issue. You don't hear much of Hall sensor problems....
Yeah I'll bet you're happy.
I used to have an occasional clunk that turned out to be a bad shock. Best of luck.
#92
Received 1,679 Likes
And, I can do that job right in my sleep. I was really not worried about an intake problem.
But all's well that end's well.
Oh and tools. Does anyone make a 'gear wrench'-like tool that will undo Allen bolts? You'll KILL for something like that if you ever do the Hall sensor.
BTW, John, I've pointed folks at your excellent t-belt procedure. If I haven't thanked you in the past for that yet - let me say now: Thanks!
#93
#94
Originally posted by SharkSkin
Would something like ...
Gonna have to get me some a'dem.
A ratcheting Alan wrench will shave an hour or maybe more from the Hall sensor R&R. Won't let you get to it without removing the cam cover. But, your fingers and hands will thank you.
#95
Originally posted by Old & New Do you see the spec. pressure of 55-60 psi with engine off?
It may be a moot point now, but I am just tying up loose ends.
#96
In any case my idling pressure is closure to 48 PSI and 55+ with no vacuum.
I didn't do a 'relay bypassed engine-off' test. But, I suspect that the idle test with no vacuum/strong throttle blip at 55+ psi is a good indication that my pressure is OK.
Last two thoughts:
- we'll see on the dyno on Saturday how close to spec the power level is
- I'll bet that there are still a few things wrong with the '89 and if the dyno says the same then I'll chase some of the good ideas tossed into this thread.
#97
Last two thoughts:
Last two thoughts:
270 rwhp
Paaaaa-thetic. (But still about 100hp up from when this thread started.)
The curve shows the characteristic zig-zag of timing being retarded then advanced then retarded then advanced - i.e. knock sensors kicking-in.
The most-likely culprit is [Edit: removed incorrect earlier statement which was based upon what the Dyno operator told me, and that was wrong, wrong, wrong. (Maybe not for a small block chevy but wrong for an LH 928.)]
In the meantime baby's got a fresh new oil pan gasket, new rod bearings, ford motor mounts, and Eibachs with Koni externals with my 17" Fikse forged wheels (avatar) and new SO-3s, so I'm going to DRIVE!!!!!!!!!!
BWWWAAAAAAAAAAAAAAA!
Ok, maybe with that looser dyno score (for an '89GT) there'll be no burnouts, but the twisties are gonna quake in fear.
Last edited by worf928; 04-22-2006 at 09:51 AM. Reason: Removed incorrect information
#98
You may want to check this thread for other suggestions. You could also check the WOT sensor. Another easy trick, would be to swap the brains from your two GT's and see if the LH may be the culprit??
https://rennlist.com/forums/showthre...hreadid=142351
#99
