Oil Cooler 1990 GT Repairable?
I have a slow but significant leak from the left side of the engine oil cooler located under the radiator. A quick look around on eBay shows nothing available used and new seems to be at least $550.
Does anyone have experience with repairing these coolers and what was the outcome? Mine is leaking from just inside the left end where the fins start.
Anyone have a good used one?
Archive Gatekeeper
Contact these folks and see whether they're still willing/able to repair it:
Pacific Oil Cooler service
https://www.oilcoolers.com/
Kevin
Thanks Rob, I called and spoke to them. I would obviously have to send them the cooler and they would charge approximately $250 to repair with no assurance they can repair it. So best case 250 plus shipping both ways (assuming I want it back) and worst case I send it and they can't repair it. I'm beginning to feel like the ridiculously expensive OEM unit is the way to go. I think list is around $775 with some dealers discounting into the $500's. I'll have to shop around.
Former Vendor
I "gained" a client who had cracked/had leak 5 oil coolers on his GTS. His original cooler lasted for many years and his replacements all failed after about a year.
He was, of course, pretty sick of having to buy new oil coolers.
And was really upset that Porsche would supply an oil cooler that failed so quickly.
All because the idiot that replaced the first one didn't know/do anything about the deteriorated rubber mounts.
Once the mounts are gone/worn out, the cooler is essentially solid mounted to the two frame rails (which flex and move about.)
So, the failures had nothing to do with Porsche's quality.
You "twist" an oil cooler between two solid mounting points and it is going to fail!
Really important to find the correct mechanic for these cars....someone who knows all the tricks and what causes what.
GUMBALL (06-06-2024)
And if you don't fix the rubber mounts for the oil cooler, the new cooler will fail promptly.....
I'm pretty sure I have a good used one. Bought it as a spare for my GTS, but never needed it. Been in storage above my garage for about 10 years! Let me know if you want me to check the 'stash' to verify it's still there. Price would be 60% of 928 Int'l price plus shipping.
Send me a direct email at: kitttyandgary at verizon dot net I don't check this site daily any longer!
Gary Knox
West Chester, PA 19382
Gary Knox
Former Vendor
Yes. Porsche no longer has them. I have a replacement which I have used for years, with great success.
$10 for a pair.
We keep that cooler in stock at a great price, too!
$10 for a pair.
Thanks all for the assistance, I ended up ordering a new one from Sunset, $575 plus free shipping. Not cheap but worth the peace of mind over a used or repaired one. I will call Mary for the rubber mounts.
I'm going to have to try to get mine repaired, as I guess there are no other options now
I've had a crack in an aluminium engine block repaired with success, as shown below
I think I'll try the guy who did the repair for me
I guess I should be pleased mine has lasted for about 15 years
Why do you write "no other options"? They appear to be available on Porsche sites and Roger's.
I had to replace mine ~5 years ago. My lesson learned: correct ride height = not hitting parking lot barriers. At least that's how I killed mine...
Picked up all parts needed from Sunset last year and replaced my leaking oil cooler after trying to fix the old one without any luck. Make sure you replace the worn rubber grommets also.
The following 2 users liked this post by voskian:
Bertrand Daoust (06-07-2024),
Michael Benno (06-07-2024)
https://rennlist.com/forums/928-foru...-on-91-my.html
UKKid35 (06-07-2024)
