Automatic transmission not engage
#406
Hi Schocki,
I have the new modulator 😉
Fabien92 (09-11-2021)
#408
Merci Shocki ! Great video.
At 20:37, he says that the cap adjusts the modulation pressure on a half turn only (0.2 bars). I did it, nothing better. Right now, on my car I think it is at 4.6 bars (instead of 4.4 bars).
My cap is not in a good state. Before to remove it again and to break it, I prefere to wait for my new modulation valve and its new cap.
Schocki (09-12-2021)
#409
Hi Shocki
I am always waiting for my modulation valve ...
When it will be there, I will chnage it and I will check the modulation pressure (4.4 bars).
If my problem occurs again, I will check B1 and B2 pistons, and then command valves in valve body.
Waiting for that, there are some videos from 2 to 3 gears. See RPM and sound
Have a nice day !!
Have a nice day !!
#410
Hello Fabien,
Thank you for the videos but it looks like the RPMs are not increasing during the shift from 2nd to 3rd. What normally happens with a bad vacuum modulator or low pressure, is a monetarily increase RPMs while the shift happens. It looks like your RPMs don't increase like the typical phenomenon.
#411
Hi Shocki,
What happens ? B2 piston ?
The modulation valve is at the customs. I will have it today or tomorrow. I hope to plug it before the end of the week. We will see very soon now
#413
In level position 2, RPM increases but MPH doesn't increase.
In level position 3 and D, RPM increases but MPH doesn't increase before to shift in 3rd (or 4th).
If I remember, I feel the upshifts two times after 2nd. So I think it shifts first from 2nd to 3rd, and later from 3rd to 4th.
#415
Car stopped and selector in 2nd, the car moves forward.
#416
You're in 1st gear, when the selector is in 2 when stopped. You should feel a jolt when the transmission shifts into 2nd gear when you're driving.
That's why the factory decided to let the car roll off in 2nd gear normally.
#417
Bonjour Shocki !
No jolt when I start in 2nd.
In the following video, I am in position 2 and car stopped.
BTW, the new modulation has been delivered this morning.
#418
Basic Site Sponsor
Basic Site Sponsor
Yes, there are "offshore" parts, which have a service life exactly like you would expect, given the price.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#419
Basic Site Sponsor
Basic Site Sponsor
Bonjour Shocki !
https://www.youtube.com/watch?v=BM4hgApncgs
If the car is in drive....not in 2nd or 3rd....what happens when you drive off from a stop?
#420
It's the same when I drive off from a stop in position D. No jolt until it shifts in 3rd around 3100 RPM after a "slipping" around 2400 RPM.
Videos taken 15 minutes ago :
