928 Forum 1978-1995
Sponsored by: 928 Specialists
An Extremely Extreme GTS
Old 05-06-2022, 09:39 PM
  #256
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Originally Posted by IcemanG17
Bump steer.......in all the race 928's I built or was involved with, never really had an issue. Casper would bottom out in some of the high G corners with mid corner bumps and it never really upset the car? As my pace increased, I kept increasing the spring rates (especially in front) and re-valving the front shocks to compensate. I must admit Turn 8 at Thunderhill around 100mph at 1.5-6 G and bottoming out (look at avatar) is kinda freaky.....
Watching an extremely fast BMW M3 (national champion GTS3 car) he would take T8 dead flat....like a miata but SO much faster....however he is an extremely skilled driver with top of the line aero and the car is built to the limit of the rules.....he also happened to be 9 seconds per lap faster than Casper.....despite my slight power/weight advantage
There's a good one or two underpasses in a curve here where a lowered or totally dead suspension 928 will wiggle left and right at both ends pretty disturbingly at speed, to the point that it will induce a quick 1-2- punch of under and then oversteer as each end reacts differently, and at different times.
No car is immune to this.
Old 05-06-2022, 11:40 PM
  #257
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,470 Likes on 1,466 Posts
Casper looks really low on that one corner.
That picture appears like the left front corner is around 75mm.
Casper had some version of an off the shelf 928 shock?
IE: Stock 928 Koni just re-valved?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 05-09-2022, 06:20 PM
  #258
IcemanG17
IcemanG17's Avatar
Doc
No.....casper has bilsteins custom valved with Heim Joints top and bottom.....they were custom made by the previous owner I believe..... I think the rest of the suspension bushings are stock
Old 05-09-2022, 06:52 PM
  #259
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Doc
I was almost certain that this was the case looking at Casper going through that corner.
Unless something was very wrong, stock shocks and associated pieces could never get that low.
BTW.....That right front suspension has over 1.0 degrees of toe out (~1/2" of toe out), at that height!
The "toe curve" on a stock 928 (173mm front ride height) is really fantastic....very little change in toe, through the operational range of the suspension. They did an exceptional job, at the stock ride heights!
And stays fairly reasonable until ~145mm ride height. (The stock shock "bump stops" are involved in the front spring rate at 145mm, so suspension compression is severely limited, below this number, on a car with stock length shocks and stock bump stops.)
Below 140mm, the toe curve gets terrible, very quickly...but by then, the stock bump stops are very involved in the front spring rate (and the cars are understeering enough (from the increased spring rate) that this height can not maintained for very long), so stock cars rarely get this low.
......However, in all fairness to Porsche, the cars were never designed to operate at ride heights or cornering heights this low
Old 05-10-2022, 07:19 PM
  #260
IcemanG17
IcemanG17's Avatar
Doc
I texted you the pictures of Caspers Heim joint suspension, its 4 pics top and bottom front-back.
I do recall putting on 1025lb springs in front plus a very high durometer bump stop on the shock shaft? Sean still says it bottoms out, but he does weigh just a smidge more than me :>
Honestly I never had an issue with rear suspension, only the front would bottom out....I did read an old post of mine that said it was set to 140mm front and 150mm rear using stock measurements.....
Whats funny is the Estate running stock shock top-bottoms had bilsteins with cut eibachs and it NEVER bottomed out in T8......it was quite low too...I guess the bump stops were working....it was only 4 seconds slower
Feel free to post the pics if you think it would help
Old 03-24-2024, 02:16 AM
  #261
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,616 Likes on 1,262 Posts
For those that might not have seen it on Facebook, here's some beautifully shot video compiled by David Mavro from a marathon session at Thermal this week. The slow-mo footage is part of assessing suspension motion in the various turns there.
The following 14 users liked this post by Rob Edwards:
Andrew Schauer (03-24-2024), Bertrand Daoust (03-24-2024), Constantine (03-24-2024), Daniel5691 (03-25-2024), Darklands (03-24-2024), Dave928S (03-24-2024), dimi5928 (03-25-2024), hacker-pschorr (03-24-2024), jcorenman (03-27-2024), JWise (03-24-2024), Mavrolous (03-24-2024), Michael Benno (03-24-2024), Mrmerlin (03-24-2024), Shirah (03-24-2024) and 9 others liked this post. (Show less...)
Old 03-24-2024, 11:16 AM
  #262
Constantine
Constantine's Avatar
Any thoughts from the pilot on the experience of driving this beautiful and capable 928 during this event?
Old 03-25-2024, 04:55 AM
  #263
john gill
john gill's Avatar
I bet that felt good , the car looks very comfortable at high speed ,the stock suspension would not well done all thanks for the video
Old 03-25-2024, 05:37 PM
  #264
GUMBALL
GUMBALL's Avatar
Originally Posted by Petza914
Greg, this is very cool.
To solve the transmission torque problem, why not use the C5 or C6 Z06 setup that already has a decent limited slip integrated into it and can withstand in excess of the 500 HP those cars produce in combination with your new clutch. Other than the the shift ****, looks stock enough from the inside except for that extra gear in the pattern of course. For a higher HP build, those ratios are actually quite well matched too and the carbon fiber synchros hold up and work quite well. Just curious.
Just curious, have you looked at a Race box ?? Something from Hewland or X-trac ?? I understand that these are non-synchro, but with a little practice, they are not a problem shifting.
OR, you could look at the selection of "paddle shift" options.
Just curious . . . .
Old 03-25-2024, 06:28 PM
  #265
Petza914
Petza914's Avatar
Received 6,266 Likes on 3,991 Posts
Have I, no. Once I fix the bearing issue in my torque tube I'm very happy with the Z06 trans setup I have in that car.
I'm not sure Greg, who put this Tilton clutch together, is on here anymore.
Old 03-25-2024, 09:17 PM
  #266
IcemanG17
IcemanG17's Avatar
I think this GTS 5 speed was totally gone through by Doc to handle the extra power and torque!
Quick Reply: An Extremely Extreme GTS
