928 Forum 1978-1995
Sponsored by: 928 Specialists
oil pan/gasket trivia
Old 08-06-2023, 03:16 PM
  #31
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,437 Likes on 1,366 Posts
to be fair,
if you use blue thread locker on the pan screws no matter what gasket you use ,
the bolts should stay where you put them.
Old 08-06-2023, 08:10 PM
  #32
ador117
ador117's Avatar
I will tight them again and try the blue locker the next time.
cheer’s
Raphael
Mrmerlin (08-07-2023)
Old 08-07-2023, 12:52 PM
  #33
Gary Knox
Gary Knox's Avatar
Another option is to use some Drei Bond on the bolts. This both seals against the oil seepage and tends to bind the bolts in position.
Old 08-07-2023, 07:35 PM
  #34
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
I spent an entire year having prototypes made, using a mare modern gasket material, until I perfected the hole pattern to ensure a perfect fit of my gasket.
I didn't do that because the factory cork gasket worked well!
Since this thread is so old, it is worth mentioning that Roger no longer sells our gasket, but sells one he had made, after we quit doing business with him.
To get our perfect fitting gasket, you need to call us directly.
Old 08-18-2023, 06:12 PM
  #35
ador117
ador117's Avatar
Bonjour Greg,
For sure I would like to get your gasket. Your advises have been so important to help me reworking my engine with no major issue so far after 2000km (1250 miles). I only have this oil leak trough the clutch hole...
I will be in the US next week in Washington area. But for only few days. too short to organize a shipment. Next time I come back in your country for more days I will contact you to get one.
Maybe next time I go to San Diego (I usually land in LA) I will be able to visit you in your shop?
Cheers,
Raphaël
Old 08-18-2023, 07:14 PM
  #36
GregBBRD
Former Sponsor
GregBBRD's Avatar
Originally Posted by ador117
Bonjour Greg,
Cheers,
Raphaël
I'll look forward to that!
Quick Reply: oil pan/gasket trivia
