1980 Restoration/Restorod Project.
As you know, there's a bunch of pieces to one of these cars....especially when they are apart to this level.
Definitely time to reassemble!
And I'll second the inquiry on what the "Rod" upgrades will be?
mine is not stripped to that point. But i am excited by just looking at those results. That is a stunning color.
who does the paint work for you out there.?
And what was the time involved after it was dropped off to this point.?
i have a shop here locally i am leaning towards, but i will trailer my car from vegas if i had to to get a top job like that done with a place that knows these cars.
Also, every single guy here 100% realizes how much extra time and effort it actually demands to
1) Do the actual work itself
2) Then also stop everything right in the middle of a real ongoing job and take a picture
2 b) Then also again stop everything right in the middle of a job and take another picture
2 b+1) Then also again stop everything right in the middle of a job and take another picture . . .
3) Load the pictures onto a computer, arrange the pictures, upload the pictures, supply text, edit mistakes, etc etc etc
4) Finally post up.
So, thanks to you specifically, and also thanks to all the people who post up this type of priceless knowledge on RL for us.
Dan
4) Finally post up.
Dan
+928! 👍
The goal is simple: Make an early 928 brand new and better than anyone else can imagine or build.
More power (~375hp with emphasis on torque) with increased fuel efficiency, better exhaust with better sound, increased braking to match the increased performance potential of the new car, better suspension with shock valving and travel to compliment a lower stance, better handling by adding a limited slip, spring rates, and sway bars to reduce the 928 factory understeer, and more rubber on the ground with the tires and wheels filling the wheel wells....the list it goes on and on.
He doesn't/refuses to cut corners...the car sat for a month, once the body work and primer were on, to allow the primer to shrink...then he blocked it out the final time.
While he's not crazy expensive, he's also not cheap (I'm not looking for cheap, BTW.) A "basic" prepare and repaint (with normal dings) is 10-12K. I furnished all the replacement panels, doors, fenders, etc. for this car, but he had to do all the labor to cut off the quarter panel, the inner structure, the door jamb, etc. He fit all the doors to make sure the door gaps were perfect. The "tab" on this car was 17.5K, but I didn't pressure him and he worked at his own pace....the car was there about 5 months. (But he's not very busy, right now....his "main" business is repairing small dings in high end cars...and the Virus has a bunch of those car parked, at home.) I took him an '84 911 Cab, last week, and it's already well on the way to sitting for its final blocking.
The "problem" with either of those prices (10K or 17.5K) is that it takes a whole bunch of time (labor) to take the car apart and put it back together. And all new rubber pieces are now over $7K, from Porsche.
It's petty damn easy to have 25K in a "paint job", when you toss in the cost of the rubber pieces, along with disassembly and reassembly. (This car will certainly be higher than that...17.5K (paint and body) + 3.5K of body parts + 7K of rubber is "bigger" than 25K....before we even touch it!)
It took over a year to get from pic #1 here to pic #2 and I'm retired!
This is how it was advertised!
Stripped.
Since the glass was very nice, we simply removed the trim for them to paint "around the corner" and down to the glass.
As far blasting pieces is concerned, I'm not convinced that problem can ever be solved...one time my powder coater does fine and the next time he ruins everything I hand him.
I just have to make sure the alcoholic that actually does the blasting is "retrained" every time....and go over and "burp" him, just before he does my stuff.
I wish it was practical to send stuff back and forth to Texas, but currently, shipping charges are....crazy expensive.
That's a brand new factory battery box, which I personally surgically removed and welded back in.
That 951, in the background, is an absolute work of art....also a complete restorod. I'll post stuff about it on the 951 site, soon.
