928 electrical problems
Hello,
I recently bought a 1978 Porsche 928. This was imported from Germany to New Mexico many years ago and has never seen snow and was never left outside. It has been in storage for 10 years plus It is ultra clean and clean rust free underneath. BUT it has a few electrical problems I need help with. First I would like to replace all the dash panel incandescent bulbs behind the panel (19 small ones?) with LED bulbs. Also the 3 larger ones. Anyone have a place and part # that will work?? Also, so far, the speedometer and odometer do not work. The gears on the odometer are all good but I may replace the large 1st gear anyhow since people seem to have a problem with it deteriorating. There are 2? electrolytic caps on the speedo pc board and one is shorted and blown. I think it's a 100 mfd/16v. And a resistor wired to the pos of this cap is badly burned but does check 33 ohm out of circuit. Color code is burnt off. I need to know what this resistor is and I could really use a scrematic for the speedometer board. Any help will be greatly appreciated. Thank you Porsche owners.
Team Owner
Welcome with your new project,
please post pictures of the electrical damage
Welcome to the tank! Apart from what you have posted, everything else works? You have done very well indeed! Speedo is driven by pulses from a reed relay on the back cover of the diff, but the usual problem is poor contact at a connection in the front of the spare wheel well, under a plastic cover - disconnect, apply Deoxit, reconnect, try again. While you are in that area check out the battery (under the spare), its posts and ground cable. In all electrical problems Deoxit is your friend. MANY electrical problems come back to failed relays, especially fuel pump, which is a special , although readily available. Other common problem is botches perpetrated by previous owners/mechanics trying to save $, not knowing what they are doing. Get a set of manuals - soft form is available from Jim Morehouse, who sells through our vendors like 928srus (Roger T).
Remove the CEB cover (pax footwell) and check the fuses, look for signs of excess heat anywhere, remove and clean fuse ends, clean and Deoxit the contacts.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
Welcome.
The list of issues from Jpitman is common, but I think you identified a couple of bad capacitors on the board. This happens, although not as often.
There have been threads on the repair, I can't remember or find them right now.
Same with LEDs. Some folks have replaced them.
Some diligent searching may generate results. Or someone smarter than me may be able to point you in the right direction.
And, as is tradition on here...
THIS...
THIS...
chuck Basics (01-26-2020)
Welcome!!
I just replaced all the bulbs on mine, but with incandescents. Here’s the process of pod removal, with some handy links: https://rennlist.com/forums/928-foru...l#post16362998
On the speedo, three words: Palo Alto Speedometer. I just had the work on mine when I had the pod out, and they know their 928s. They replaced two caps on mine (preventative), replaced the broken odo gear, and calibrated it. Works great.
Finally you will need to familiarize yourself with our famous instrument flexible PCB aka foil. See post 150 in the above thread for links to Dwayne’s great refurb threads and inspect yours as appropriate.
Oh, Roger (ROG100) sells an update kit that replaces all the bulbs with LEDs AND uses hard PCBs, getting rid of the old foil. That might be perfect for you.
THREAD...
Rick
THREAD...
Rick
Bill Ball (01-26-2020)
There is not much to post and will not help I think.. A burned resistor is a burned resistor. It also burned the circuit board black under the resistor. And a shorted capacitor just swells up and pushes out the rubber plug on the bottom and checks shorted. All I need is what I asked for. Thanks.
Team Owner
Team Owner
since I can not see what your working on,
and the parts you have ,
you are the smartest one in the room,
good luck
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
Very funny. You don't need to see a burned resistor to know it's burned. And a photo of a shorted capacitor will tell you nothing. I asked for a schematic of the speedometer and a source for LED pane lights. That's all I need. Then I will know it all. Thanks!!!
Team Owner
Chuck what your missing is that you have a part that no one else knows what you have,
SO your the smartest man in the room.
NOTE the pod panel your working could be a Euro version,
or a USA version,
or a one off version since your working on an early machine.
Your wave circuit could be damaged or shorted or the connectors damaged.
NOTE if you wont give the info requested your chances of getting the correct answer diminish rapidly.
NOTE this is not how to make a good first impression with the people that could best assist you.
or a USA version,
SeanR (01-26-2020)
Put what you are looking for in your Google search bar and add Rennlist and 928, then read the links posted in the search results.
Did you say your name was Richard?
Welcome.
THIS...
THIS...
