WYIT block split
Replace only the nuts, which get high torque. The low torque bolts are fine to re-use.
Block build up
Soooo,
Plan is below.
Finally got the rod nuts/bearings, rings
Mains/ new girdle nuts arrive next week.
Current plan;
* Is assembly lube used anywhere on lower half? Or just oil?
* loctite / antisieze on any bolts/nuts?
Any other helps?
Install pistons, rod bearings, and new nuts
John
Plan is below.
Current plan;
- Continue cleaning the crank - oil passages seem like they are cleaning out well. I have made some air nozzles and straws that get into the passages well.
- Not modify any oil passages, as the threads are not decisive. At least I cannot find anything specific. Chime in if other is advised.
- Perform TB 8806 on the original pistons / oil holes.
- Balance Pistons - Possibly rods
- Balance crank? Is this necessary?
- Find the correct roller for the sealant application. HELP???
- Tank everything again
- Check crank oil passages again
- Install the mains.
- Install crank
- WSM directs to install oil seals. Is this necessary or recommended at this time?
- Roll out sealer
- Join halves
- Install oil pump
- Torque as advised
Any other helps?
- Verify piston/rod orientation to block
- Correct ring gaps
- Correct ring positions
John
Special nuts??
After looking up the spec on the M 10 nuts I am wondering if I need to get them from a Porsche vendor or do standard hex nuts with nylon insert that are grade 8 sufficient.?
About 4 dollars difference each.
