928 Forum 1978-1995
Sponsored by: 928 Specialists
TIG/MIG Welding Reynolds 390 Aluminum
Old 08-01-2019, 02:47 PM
Kiln_Red
Kiln_Red's Avatar
Question TIG/MIG Welding Reynolds 390 Aluminum
I'm hoping we have a BA welder on the board that can offer insights about welding on Reynolds 390.. The aluminum alloy that our engine casts are made from. I could end up with a project that would make welding on the block necessary, but don't have the knowledge of what rod or wire would be most ideal for this application. TIA!
Old 08-01-2019, 03:33 PM
Bigfoot928
Bigfoot928's Avatar
Old 08-01-2019, 03:40 PM
77tony
77tony's Avatar
If Joe doesn't spot this thread shoot him a pm: "Polecat702"
Old 08-01-2019, 03:44 PM
Kiln_Red
Kiln_Red's Avatar
Old 08-01-2019, 03:47 PM
Kiln_Red
Kiln_Red's Avatar
Noted! Thank you.
Old 08-01-2019, 05:55 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,321 Likes on 1,295 Posts
Greg Brown will know what welding material is needed as well as Joe
Old 08-01-2019, 09:26 PM
polecat702
Vegas, Baby!
polecat702's Avatar
You'll need to be very specific, as to what you need welded. You will never wire weld an aluminum engine block, without the base metal failing or the weld itself failing. Can't get the penetration needed. It's got to be clean, as in surgery clean, preheated jigged up to control distortion, and warpage.
I'll need a lot more information to write a comprehensive welding procedure. No run of the mill welder will be able to weld this alloy. Welding aluminum is an art in and of itself.
Here's my take based on silicon content. For a block with 7%, my first choice would be TIG Rod, 3/32 2139, 2nd choice ER4043, or Alloy 5 6061, depending on the application, and location of the base weld. This is TIG welding only. Forget wire. This rod will work for a range of 7 to 12 % silicon content in the base casting metal.
The following 2 users liked this post by polecat702:
SeanR (08-01-2019), worf928 (08-05-2019)
Old 08-01-2019, 09:48 PM
Kiln_Red
Kiln_Red's Avatar
All I am looking for is the most appropriate rod for this alloy.
Pulse MIG has changed my thinking about the limits of wire feed welding. I don't know if it is an impossible solution. TIG should be better.
Old 08-01-2019, 10:07 PM
polecat702
Vegas, Baby!
polecat702's Avatar
I have a MIG welder that allows me to download the panel welding parameters from Ferrari, on my laptop to the welder. I'll run continuous once the panels are tac welded and clamped to prevent warpage. I bought the welder from the SEMA Show,around 12 years ago. It was $ 26,000.00 then, and I snagged it for 19K, after the show. It's a Lazar pulse, one of the first. I wouldn't try it on anything heavier than 18 gauge sheet metal, continuous, 16 max stitch welding.
What ya really need is a good Heli-Arc machine. Scratch TIG, is OK, but you need the heat control that only the pedal can give, maybe a purge box too, and proper backing gasses.
Old 08-01-2019, 11:18 PM
Bigfoot928
Bigfoot928's Avatar
and the block will need to be heated.
Old 08-02-2019, 12:36 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,470 Likes on 1,466 Posts
The engine block is made out of aluminum?
Wow! That's super cool!
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 08-02-2019, 01:41 AM
Kiln_Red
Kiln_Red's Avatar
EXACTLY what I was looking for.. Thank you! I have effectively used pulse MIG for replacing components of the C7 Corvette frame as that is required by the GM P-Sheets. IIRC correctly the metal at the rear frame rail ends was only 14 gauge and I did note that achieving any meaningful level of penetration required near max duty by the machine's capabilities.
It's the primary base material, so I am satisfied to call it 'aluminum'.
Old 08-02-2019, 03:45 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
The last one we fixed had corrosion damage at the very top of one cylinder. We ground out the corrosion...ended up pretty deep. Pre-heated and TIG welded with a special rod. Ended up perfect.
No cylinder distortion....ended up only needing to cut down the weld and surfacing the deck surface a couple of thousanths. Didn't even need to touch the bore!
EXTREME LEVEL OF SKILL REQUIRED! We took a "donor block", cut chunks out of the top of cylinders and practiced various techniques, filler rod, preheat, and shielding gas, before attempting.
I was mentally prepared to have to put an Alusil sleeve in this block.
Old 08-02-2019, 09:24 AM
Kiln_Red
Kiln_Red's Avatar
Looking forward to the challenge.
Without a spare block, I probably wouldn't mess with it.
Old 08-03-2019, 03:24 AM
The Forgotten On
The Forgotten On's Avatar
Would any of this apply to repairing the alternator bracket attachment points on the block?
I know the lower half is a different metal than the upper half and less finicky IIRC because of the much lower silicon content allowing a "cleaner" weld.
Quick Reply: TIG/MIG Welding Reynolds 390 Aluminum
