FS 928 parts
FS 928 parts
Clearing out the remainder of my 928 parts the numbers in front of the items are my inventory numbers with the prices behind it all items are priced excluding freight or postage to your destination for those that buy multiples I will combine the freight. Items are sold based on the order/time of PM's received.
613Water bridge50 Sold GreggBBRD
651Termostat elbow20 Sold GreggBBRD
147Intake complete950 1 Dib GreggBBRD chk casting #
541gaskets spark plug holes15 Sold
604Vac hose 5 way3 SOLD Kevin W
630O rings5
651o rings5 Sold
819compression rings
856steering rack covers20 Sold
26Intake fittings30
140Trans rubber15 Sold
208Idler by pass25 Sold
304Sensor plate PS cam10
340Cable attachment on intake35
431mirror connection door plugs15
525EZK200 Sold
610Abs module50 Sold
657Fan motor regulator100 Sold
745Coolin fans flap control25
901PSD slave cylinder35 SOLD GreggBBRD
950PSD new o ring PSD slave20 SOLD Brian
455Interem shaft100
525Cam cover gaskets15 Sold
601Memory seat controller200
641Radio distortion suppressor15
719HVAC flap contol module30 Sold
831Assorted belts20
859X pipe gasket packing15
928Seat controller15
17Shaft coupler25
214Throttle valve quedrant15 Sold
356Cruise control module35
443Mirror glass set15 Sold
508Fuel hose U40
548Eng coolant plugs10 Sold
632Fuel hose between regulator15
646Frt lic plate holder20
731HVAC drain hose10
744Oil filter5
845Rubber hose10
924AC dryer and pres switch5 Sold
956Rear bumpers10
21rear suspension arms20
45Charcoal canister valve10 Sold
148Ground straps for coils10
250Steering contact ring20 Sold
350Sunroof motor35
520oil pres valve30
709Rubber stop for hood10
835water pump gasket10
909rear sun visors Navy20
946Assorted rear light fittings25 SOLD Kevin W
58Valve cover gasket20
356GTS rear rub strip sections30
605Rear hatch shocks30
708Radiator plug5
720Rubber elbow from idler15
844Wheel ABS sensors10
939Gasket from air intake filter10 Sold
48Gasket for intake side covers10 Sold
HVAC unit complete150
630O rings5
651o rings5 Sold
26Intake fittings30
525EZK200 Sold
455Interem shaft100
831Assorted belts20
17Shaft coupler25
508Fuel hose U40
744Oil filter5
845Rubber hose10
956Rear bumpers10
350Sunroof motor35
520oil pres valve30
708Radiator plug5
541 spark plug hole gaskets
950 PSD O ring
525 Cam/ Valve cover gaskets
939 gasket from air intake filter
48 gasket for intake side cover
i don’t need #950, PSD, I already have a spare.
I want a waterbridge with 2 temp sensors to replace my waterbridge with 1 sensor. But I see you have 3 different versions. Which one will fit my 4,5L engine?
Former Vendor
I will take:
719,214,443,45,250,208,657,610,924,651,659,
613, 633, 641.
If Brian doiesn't want the 901 PSD slave, I'll take that.
Is the intake manifold a 2R or 4R casting? (Look from the bottom on the actual intake.)
613, 633, 641.
Former Vendor
Gregg
Got yours set a side and checking the cast # I think I see in one of it's pictures "2R" will confirm later - It came of an 1989 engine that had 21k miles
Intake confirming R2
Former Vendor
Have plenty of 2R, so I won't want that one....although with the original paint on it, you should be able to sell it, easily. (Easily worth what you are asking to someone who is trying to keep things really original.)
And if you still have it longer than you desire and decide to "fire sale" it, I'd gladly look again.
Damn Herman. We were waiting for a semi list from you so we'd know what we were buying.
