Here's a fun little engine. Stock GT that's a 5.8 liter.
#46
Basic Site Sponsor
Basic Site Sponsor
Of course, the "trick" with the relatively tall gearing of the 928 is to not trade too much torque for horsepower.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#47
So, it sounds like you have created a kind of "GT Plus," and I am sure it runs fantastically. I always "imagined" that a full stroker would shift the 928s character in the spectrum slightly towards "muscle car" character. To me, the 5.8 approach sounds like a much more appealing route, especially with a manual and especially given the ability to use more stock parts.
But the "stock" aspect is where I am having trouble understanding what you are actually doing. What exactly is stock on this approach and what is changed? I tired to do the math just to understand it for myself and not to pick nits about rounding errors:
Standard GT: stroke 78.9, bore 100, displacement 5
Standard GTS: stroke 85.9, bore 100, displacement 5.4
Build Mentioned in First Post: stroke 85.9 (?), bore 104, displacement 5.8
Build with GB CS: stroke 95.25, bore 100 (?), displacement 5.9
If I had a damaged motor, like the one described in the first post, the 104 bore would be the way to go. If I have a stock GT with a block still in great shape, I would be hesitant to change the bore to 104. So, is this 5.8 concept still possible? Or, do you need to use the 104mm bore? Whatever the case, congrats! Very seductive approach that harmonizes with the overall concept of the 928.
#48
Basic Site Sponsor
Basic Site Sponsor
Currently, there are no oversize pistons available for the '85/'86 pistons or the GTS engines. (I'm building a GTS engine, right now, with first oversize pistons. I had to gather up pistons from a bunch of various sources....some very old stock, with different variations in rings, which I had to "fix".)
In some cases, like the engine in this discussion, there were very limited alternatives.
The good thing about using a 104mm bore is that should anything "go wrong", there is always a "repair" size of 104.5mm.
As far as a 95.25mm stroke by 100mm bore (with stock, available pistons) is concerned, the connecting rods would have to be very, very short. I'm dubious that this would be a viable combination.
In short, I see no downside to the 104mm bore.
#49
Very impressive engineering Greg! You build so nice things so far away!
Achtung Höchstleistung
Seien Sie vorsichtig bei der Verwendung vom Gaspedal
[img]blob:https://rennlist.com/774a75ef-222e-4b61-acd3-efc205ddc4bd[/img]
#51
greg, a lot of enjoyment for me is doing as much as I can myself, and also saving labor costs. are you willing to sell a component kit for building a motor like this?
I would bet there are others that would be interested as well.
#52
#53
Yeah, but stock exhaust and intake and heads - not sure what you complaining about. This is a great starting point for the owner to go farther later. YMMV
#54
It sounds to me like a winning a proposition in a number of scenarios.
#55
Basic Site Sponsor
Basic Site Sponsor
Given those parameters, I'm extremely pleased with the results.
And like I said, this is a "base" engine, from which we can see if other changes help or hurt the power output.
Stay tuned....we "running in" another version of this same engine, tomorrow, with cams and headers.
#56
Basic Site Sponsor
Basic Site Sponsor
I also am very generous of my time and advice...ask Kevin.
However, think of me as a master chef. I can supply the main ingredients to make a special meal, but there are many tricks to turning those pieces into a culinary delight. Plus, me supplying just the main ingredients leaves the "want to be cook" at home, free to supply all the ansulary ingredients...and he could easily pick out the wrong tomatoes or the incorrect brand of herbs and end up with a disaster.
And then, there's the obvious question: Can the person getting the main ingredients even boil water, much less combine the ingredients into a great meal?
#57
That is an understatement. Thanks, Greg.
