torque tube bearings replaced now can't turn the drive shaft easily
Hello
as part of my restoration I replaced the torque tube bearings and oil pump seals on my transmission. after putting it back together I now find the drive shaft quite stiff and cannot turn it by hand, which I used to be able to do before. Is this normal after a rebuild? I did lubricate the bushing for the torque converter before refitting
sam
85 S2 auto
sam
85 S2 auto
NO this is not normal. you need to figure out where is it binding. I would disconnect the TT from the TC housing input and see if the TC input turns freely and that the TT turns freely on its own also. after installing the TC on the trans and installing the front TC housing did the trans still rotate freely? my first guess is that you didn't get the TC aligned correctly and put it in a bind when you tightened the TC housing bolts.
You need to ensure that the converter is properly seated in to the pump before you put the bell housing on. Sometimes this can be real tricky but if you don't, you will shred your pump and then you basically have a useless transmission. Take a look at the WSM.
The good news is now I know what the slots on the TC input shaft are for. The bad news is that with the 928 I have to finally admit ive reached my level of incompetance.
Ive tracked down a few here in the UK. they run at about £140 ish ($180) used so need to decide whether to buy one or just buy an entire transmission assembly for twice as much and strip the parts
Anybody got a pic of what the broken part should look like?
I took a look in PET but could not see the specific part so presume it is a part component - presumably of the pump
Thats correct. Only sold as part of a complete pump part number 1262770320 £££ here is how it should look with the two teeth on the inner circumference. These have snapped off on mine.. The 2 slots in the TC shaft fit on the two teeth. when aligned correctly
Thought that would be the case- obviously the drive dogs for the oil pump have sheared off. I wonder if they could be welded back on given the drive load is not all that high for a pump like that. I suppose the problem may be getting someone to do a quality job for a price significantly less than the options available to you.
Former Vendor
No one person ever makes this mistake a second time.....
To save you a second "round" of grief, make sure that you lube the hell out of the bronze bushing right between the converter seal and the oil pump gears.....people forget to do that and the torque converter seizes on the bushing, which ruins both the pump and the converter...instantly.
Amazingly common mistake. for first timers:
Former Vendor
