Wait just a minute....what's the deal with that pan gasket?
#46
- The Lucas motto: "Get home before dark."
- Lucas is the patent holder for the short circuit.
- Lucas - Inventor of the first intermittent wiper.
- Lucas - Inventor of the self-dimming headlamp.
- The three position Lucas switch - Dim, Flicker and Off.
- The Original Anti-Theft Device - Lucas Electrics.
- Lucas is an acronym for Loose Unsoldered Connections and Splices
Why do Brits drink warm beer?
Because Lucas makes refrigerators too.
It's a good thing the movie maker George Lucas was not related to Joseph Lucas. If he had been, Star Wars would have been 2 hours of black movie screen.
In a quick search for Lucas jokes, I found this:
http://www.mez.co.uk/lucas.html
Scroll down towards the bottom to read the ad for 'Genuine Replacement Smoke".
It's been posted on here a few times, and I thought it would be appropriate (or inappropriate, take your pick). I didn't have to go look for it, it was there.
Make sure you read the questions.
#48
you can still get glyptal from eastwood. great product
https://www.eastwood.com/glyptal-red-brush-on-1-qt.html
We dont lack oil generally, and when we do, it's not stuck to the block.
#50
Basic Site Sponsor
Basic Site Sponsor
Looks just like the kind I can buy for my Delorean..
https://deloreanindustries.com/12-oil-pan-gasket/
#52
Received 1,543 Likes
Rennlist is having issues sending post notifications. So I didn’t see this until now.
....There's a rumor that one is coming your way, for you to play with and critique.
.....Along with a brand new design 14 pin loom with concours appropriate materials, hand built by the master, himself. Also for your use/critique.
#54
Basic Site Sponsor
Basic Site Sponsor
The oil pan and block are amazingly.
I'm assembling an '89 GT engine and just for giggles, I put 5 studs in the rear 5 pan bolt holes. Not only are they not in a straight line, they even "lean" in different directions....they are not 90 degrees to the pan rail!
While it's obvious that this was not done on a CNC machine, I'd always figured this was done on some sort of a very precise machine.
These 5 holes look like Ray Charles used a center punch to locate them and Stevie Wonder stepped in to drill and tap them at the next tree.
It's been so long since I made my pan spacers, I completely forgot that this area was so "variable".
I remember, now, why the holes in the oil pan are 8.5mm while the hardware is only 6mm!
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#55
I didn't figure the oil pan bolts for the block were done on a jig. But, I know the fuel rails were. No two fuel rails are identical.
Same for the threaded holes for the Hall sensor in the right side backing plate.
The holes in the chassis for the 'ears' on the belly pans were totally done by eye.
#56
I can also recall when the threads were not wonderful. It is tempting to just recenter them (as best we can) and retap.
#57
Basic Site Sponsor
Basic Site Sponsor
I assume that there were jigs. And the quality of parts out of the jibs depended upon who, that day, was working.
