PS leak from near reservoir
Hi,
So I have a leak from around the underside of the PS reservoir, the leak appears to be dripping down the low pressure pipe. I am assuming it is the low pressure rubber pipe going but wondered if the reservoirs are susceptible to cracking?
Team Owner
Try snugging its hose clamp first, doing so solved my leak many years ago.
Chronic Tool Dropper
On mine the hoses were no longer soft enough to seal on the little nozzles in the reservoir. When I did a pm filter and fluid change, tightening the clamps didn’t help with the seepage, so new hoses were needed.
The hoses dont last well with ATF, so I would start by replacing those ends connected to the reservoir. I had a lot of trouble getting ends to fit readily, so I introduced a steel hydraulic fitting reducer and 90deg angle to ease the size transition and direction change. Has worked well for several years now. Couple of extra hose clips involved, they are all easy to get to.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
When the hose gets older the ATF tends to seep through the wall. Tightening the clamp will not help. The hose from the reservoir to the cooling lines is attached to metal the cooling lines at the front of the car. You can cut the hose off by cutting the crimped clamp at the metal line, and a 12mm ID rubber hose will be a good replacement. I used nitril rubber version as this is more ATF resistant.
The hose from the pump to the rack is a pre-formed hose, 928.347.445.06 for my GTS. You need to buy this one as a standard hose will not fit easily.
More info here: Steering reservoir hose repair
Theo
1992 928GTS Midnight Blue
Theo
I've read here that some folks have moved from ATF to power steering fluid. Does that change the calculus of why the lines fail over time?
And the prize goes to all those who suggested the rubber hose. Replaced today, the reservoir was fine. The old rubber line was just giving up, it had a good stint at 29 years.
I am toasting it’s passing as we speak
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/b2facb16_0266_4beb_9bb3_583557599ab1_dc6ece1fbb3d5ffd8ab23fbcce5e596543e6142c.jpeg)
I had exactly the same problem and replaced both low pressure hoses when refurbing the high pressure hose. Should probably go on the pre-emptive "replace list" after 10 or 15 years of service if one wants to avoid them sweating ATF as they invariably will do. My reservoir is still holding firm but I wonder how the plastic is holding under all that heat and exposure to hot ATF.
My hoses were pretty much shot, but I chose to replace the reservoir at the same time, even though the leaks weren't coming from it.
It's surprisingly inexpensive for a Porsche part. Roger has them.
