GB Replacement Front fuel supply line
It's time to replace my fuel lines in the engine bay and I will install a Greg Brown Replacement' Style 87-95 Front fuel supply line.
Since it deletes the hardline section it doesn't routes the same way as stock, how do you route that hose around the front of the engine? Pictures?
Pic taken on GB's website
Is there another option to replace that line and keep the hard line section ? Also, are there any threads that show the replacement process in detail ? The intake refresh threads have a few pics but nothing in detail
Right or wrong, here's mine. You should have a "caution" tag on the end that's closest to the fender. Note that, that end is actually two pieces and BOTH have to be tightened once you get the line situated.
Greg also supplies a stock looking version. You have to send your hard line as a donor so he can cut the factory end off the metal at the flex hose and weld on a fitting that mates to the new flex line. Per Greg's usual attention to detail he sends the hard section out for re-plating after the mod so the whole unit looks brand new. He will not even start construction IIRC until he gets your donor part. Too many cores not returned or something similar.
Former Vendor
I'm sorry you did not get intructions with your order.
Every fuel line we ship comes with instructions. I'll work on making sure Roger is doing the same.
Basic Sponsor
Instructions are included with all GB hoses we send out. We also have them on file and they can be emailed pretty easily if required.
Former Vendor
Easy peasy.
Originally Posted by GregBBRD
......I took everything out of the original bags and did not send any instructions..... Send me your email address and I'll email you instructions for my hoses and baffle. gb
Greg, I will send you my email address.
