928 Forum 1978-1995
Sponsored by: 928 Specialists
Interior lights shorting out
Old Nov 30, 2018 | 04:20 PM
vanster's Avatar
vanster
Default Interior lights shorting out
Is it possible the these LED bulbs short out when they come in contact with the light frame?
Old Nov 30, 2018 | 05:54 PM
bureau13's Avatar
bureau13
I haven't seen the LEDs themselves short, but I've popped fuses pulling the housing in and out of the car.
Old Nov 30, 2018 | 09:00 PM
vanster's Avatar
vanster
I've pulled out the interior panel in the hatch looking for trapped wires and all OK. Change the fuse and put the light fixture back in place it will work for a few times then short out. I took out the fixture and tapped up the connectors hoping to isolate the issue. Now the rest will flicker and short out as well.
Old Dec 1, 2018 | 02:10 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
dont keep testing this as your getting closer to a meltdown,
the lights are not fused where they need to be, so you can smoke the harness from the CE panel to the lamp location,
then it requires rear quarter removal to replace the harness as well as the hatch and the roof.
best thing to do is remove the light power plug from the CE panel ,
and then test the power wire to ground with a multi meter set to continuity,
Test all of the lamps.
NOTE all of the lamps on this string must be unplugged, before you perform this test, as well as the light over the mirror.
wiggle the wire harness till you hear it beep,
thats where the power wire is shorting,
might be in the door harness bundle so a few door openings might find this, or the roof or the hatch
NOTE its a great idea to replace every one of these lamps as they are long past the duty cycle
The VW lampos are a nice upgrade and the only one that cant be replaced by the VW is the rear edge of the hatch
Old Dec 3, 2018 | 03:15 PM
vanster's Avatar
vanster
Thanks Stan
I think replacing them with the VW units is the best start. I had given this some consideration and now I'll do it.
Old Dec 4, 2018 | 08:16 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
test the wires as I suggested so you dont let the smoke out of the wires
Old Dec 4, 2018 | 08:40 PM
vanster's Avatar
vanster
OK
Old Dec 5, 2018 | 03:08 AM
The Forgotten On's Avatar
The Forgotten On
I replaced mine with the VW unit and never looked back. Just be sure to get them with the pigtails from the car.
These old lamps love to short out to the roof and cause mayhem, the newer VW units are sealed and cannot short directly to the car even if they wanted to.
Old Dec 7, 2018 | 02:02 PM
vanster's Avatar
vanster
Thanks Blake
Parts are on their way
Old Dec 7, 2018 | 03:48 PM
997TTEQNY's Avatar
997TTEQNY
the style lamp you have also can short out. They made led replacements that are the same dimensions as original OEM bulb.
Old Dec 8, 2018 | 08:24 PM
kiwiokie's Avatar
kiwiokie
VW lamps available from Roger?
Old Dec 10, 2018 | 04:00 PM
vanster's Avatar
vanster
Roger sells the lamps and pigtails
