928 Forum 1978-1995
Sponsored by: 928 Specialists
Bad Altenator?
Old Nov 7, 2018 | 07:59 PM
awilli6's Avatar
awilli6
Sean,
copy that. I’ll eventua get around to pulling the pod, but way too much to do before I get to that.
Old Nov 7, 2018 | 08:01 PM
SeanR's Avatar
SeanR
Originally Posted by awilli6
Sean,
Yea, I hear ya. Just ignore your gauges until you do that rear foil with the new kit. Of course I say that but please double check the actual temps/volts/gas level first.
Old Nov 7, 2018 | 08:09 PM
awilli6's Avatar
awilli6
Originally Posted by Wisconsin Joe
You can't pay someone to love these cars.
It's an affliction.
And for both Sean & Roger, well educated customers are far better to work with.
The bit of effort put in to educating folks pays itself back 10 fold (or better) in reduced headaches & frustration.
you’re right. I’m afflicted. It’s like a drug, it just keeps calling and calling me.
Old Nov 7, 2018 | 08:52 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
From Wisconsin Joe,
Joe thats a great observation and thanks for putting it so eloquently into words.
Thanks for all you do on this board.
I am glad your here as you teach me something whenever you write,
Stan
Old Nov 8, 2018 | 11:39 AM
Carl Fausett's Avatar
Carl Fausett
Developer
Ash, it may have already been said, but check the grounds under your dash and clean them. A lot of electrical gremlins in a 928 (especially those in the instrument cluster) can be corrected by a little maintenance on the grounds.
Just above the brake pedal you will find the folded steel steering column support, and a bolt or two holding numbers of brown wires under them. These are grounds. Porsche grounded every circuit individually on these cars, rather than using a common ground for many items. Remove the bolt, remove the ring terminals, buff them with a Skotchbrite pad or an ink eraser or whatever, and put them back together and bolt them up. Then go to the passenger footwell and do they same thing to the ground bolts that you will find above the fuse panel.
Your voltage indicator may behave better after you are done.
Old Nov 8, 2018 | 07:16 PM
awilli6's Avatar
awilli6
Will do. Thanks for the information.
Old Nov 8, 2018 | 11:57 PM
Petza914's Avatar
Petza914
Use some Deoxit on them as part of the cleanup procedure as well.
