Ground Clearance on a 928?
Hi all!
I was wondering what the ground clearance for a 928 is? Here at work they built two really mean looking speed bumps and I'm worried about scratching the car...
Too low for many driveways!
Take the offending bump at an angle instead of head-on. The wheel will meet the bump and start lifting the car over it, so that the body will be able to clear once it gets there. This technique can get a 928S over most mundane driveways and bumps. Slow and steady, get a spotter to help the first time over if you're not comfortable going it alone. Good luck
Edwill,
Listen to WallyP. Crank it up to where it's supposed to be. You will notice the improvement in ride and handling...and your undercarriage wil thank you. If you don't have the shop manuals, use 'search' to find specs and procedure, or go to Nichols' site at http://www.nichols.nu/tips.htm
Thanks guys...
I recently bought this car privately and the guy really had it customized...
Why do people normally advertise "lowered suspension" when they sell a car? This is obviously not the best thing to do. Looking cool is probably the only advantage!
Originally posted by Gretch
And it doesn'e even "look cool" on this car, It looks like the suspension is tired................
I run my car at 155 all around. Does make railroad crossings, potholes and steep driveways more difficult. But the look and handling are great!
