Wiring Harness Install
#31
2 wire version
Are you getting a new harness? From Sean@928Docs, I hope. He has the correct connectors and wire colors on everything except the later model 3 wire oil pressure sensor. Installation is easy since the wires leaving the harness are routed the correct way to fit onto the correct connectors and in the right place. Very hard to screw up the installation, even for someone who believes that electricity is "magic"!
It took me about 2 hours start to finish to replace the harness and that included changing the oil pressure sensor to a 2 wire version.
