While taking the front apart I noticed that I appear to have early model horns on my car. As it such an early S4 I thought they were probably correct, but after taking a closer look at pictures of other cars I think a previous owner engaged in some "weird DIY".
Below is Ed Scherer's picture of an '90 S4, showing the bracket and way the horns are attached:
However this is what I found on my car:
What I think happened is that the outer bolt snapped off from the bracket...…
…..And they used the support of the S4 horns to attach a pair of older style horns to the bracket:
But now what? Shall I clean-up and leave the current set-up? Or try to restore the bracket and get a pair of correct horns?
Maybe make a 90 degree bracket(v a straight one) that will bolt thru the top(in a new hole) beside where the broken mounting tab is located.
Hard core would be get a new bracket assembly and replace it, but then you disturb the coating on the frame and deal with re-coating it.
Hope that helps,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor www.928gt.com
IMHO Clean it up and leave it the way it is reworked,
this is a stronger mounting point as you have seen the early mount was prone to fatigue,
and thus the outer stud snaps off.
I have seen this on more than a few cars.
Plus you got the early horns ,
if possible tilt the open ends down so water wont fill them
Beyond this no one will ever see these unless they take the fender liner and block off plate out
Thanks Stan, that sounds like a plan!
Will clean up the bracket, order a new set of supports and 'bend' them slightly to tilt the end of the horns down a bit.
