Specific ground Issue?
While preparing the XX8 for "Sharks in Hell" I thought everything was coming together and all of the sudden the "check engine" and "anti-lock" lights came on and all gauges (excepting the volt gauge) stopped working. All other functions of the car are in order. It runs great, AC, headlights, turn signals, windows etc all work...
No: Speedo, tach, fuel, temp, multifunction display, oil pressure gauge.
Yikes! I removed and re-attached the battery ground strap and re-booted the car but nothing changed.
Where do I start?
Where do I start?
Rennlist Sponsor
Check interior light fuse, I would bet your interior lights are also inop.
Check/replace fuse #25 7.5amp and quit messing with the interior lights, you most likely tagged a positive terminal on side the metal reinforcement around the light opening, ask me how I know..LOL
Cheers,
Dave
Cheers,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Supercharged
Cheers,
Dave
Cheers,
Dave
Rennlist Sponsor
^^^^^ Merchauser, DR and AO ^^^^^ Thanks! I'll check out fuse 25.
In my preparations I did remove and replace the rear interior light to clean the area so this makes sense!
Team Owner
NOTE disconnect the battery when working on any of the interior lamps ,
grounding any of the positive wires could cause smoke to be let out of the wires
