Power Loss - Knock Sensors?
Interestingly the Throttle Switch claims to be made in Germany, but the Knock Sensors are made in Romania
Prices seemed very reasonable, at £52 and £22 x 2, p&p inc
Hopefully this will regain me some lost power, as the car is currently struggling to get over 150
I haven't put a JDS tester on the car to check for faulty sensors, so it could still be a faulty Hall Sensor
However at those prices it seemed the right thing to do, as the last time I changed a knock sensor was about 15 years ago
Fuel injectors have all been cleaned, so I'm struggling to think of another possible cause of the power loss, not that the car feels slow, but objectively it is
Having a tool to check the operation of these things is a bit of a must have- I use my ST2 in that regard.
I am hoping that the switch is at fault, as I was foolish enough (and money was tight) to fit a used switch just 12 months ago
The flappy does have such an indication. It runs a test cycle every time the engine is started. If you remove the rubber cover it’s easy to see whether it’s working, and only slightly more difficult if you leave the cover on, but stick a piece of tape on it. This will test both integrity of secondary vacuum system, and integrity of flappy vac actuator itself.
What I feel might have been warranted in the original build is some kind of real time direct indication that the vac system is viable and that the flappy operation is in play and responding- something like the PSD lamp but direct feedback from the shaft movement.
At least if it fails on test, it's never going to work at the real trigger point, so you'd learn something valuable in that case.
adding new seals will reduce false air and prevent the new TPS from filling up with oil.
I am doing an intake refresh and i took the TPS off and it had oil in the connector pin area.
I sat it on a table in the sun with the shaft opening down and left it for a few hours,
when I came back a large stream of oil had run out of the TPS unit.
I put the new double sealed shaft bearings in
I did a handful of laps in the morning once the track had had dried out and really enjoyed it with the car working brilliantly
Best not to work out the cost per lap though
The car is no longer struggling to pass 150 and was doing so on Dottinger Hohe
On the way home I did a half hearted V Max and achieved 164 but backed out while the car was still accelerating
It wouldn't have been a proper test as the sunroof was open and the headlights were up
I wasn't even breaking the law as I was on the derestricted #1 Autobahn at 2am with virtually no traffic
I don't think it was necessarily the Knock Sensors that were the problem, as the old ones looked in great condition
Instead I think it was the Throttle Position Switch - of course it could have been both
Also worth mentioning that this car has over 238k miles on the clock and is probably worthless as a result
That hardly matters as I will never sell it
