928 107 603 00 : why does it have a T-junction in latest cars, is it a test port?
While currently busy with my Intake Refresh project, I noticed that on MY1994 part 928 107 603 00 - which is the hose from the throttle body housing to the oil filler & evap vent valve - has a plastic T-junction in it which is held together with two (2) "ear" hose clamps as from the factory (see underneath photo for what I mean). On the earlier cars this appears to not be present?
Two questions:
1. As the plastic T-junction part seem to be just that (no restrictor nor one-way valves inside): is the function that of a test port?
2. Is there somewhere in the WSM where this change is mentioned? I checked all the technical bulletins, and I could not find anything in there at least...
Hope the collective here can answer this, as I'm curious why this was done.
Two questions:
Arnoud: I don't think the hose you picture is original; I don't think there is a test port at that location. In the '95 Porsche parts PDF, Katalog, that part number does not show a junction. My '93 hose does not have a "T".
Archive Gatekeeper
I've never seen any literature that points to there being a test point or 'T' in that hose, nor have I seen it on any other '94. If you could find another GTS with it, that would be interesting.
Proof #1: On the spare engine which Herman K. sold and put for sale pictures (well: pictures as part of several PDF files) here on Rennlist:
Proof #2: as per following youtube video screenshot
P.S. One possible theory on my behalf: my engine has been replaced by the factory when in possession of the first owner, which can be seen from the engine plate additional stamp of: "AT" = German for AusTausch. Most likely this was done for too much oil usage. So: could it be that on all MY1994+1995 "AT" engines, Hans & Frans had to put this in so it could be measured somehow (before returning the car with new engine back to the owner)?
Archive Gatekeeper
Duh, I have seen Herman's motor in person, should have remembered! That 'crate' motor is from a '94 5-speed, but it's not new, nor is/was it an exchange motor, there's no AT on the stamp pad. So I'm not sure that the T'd filler neck hose is unique to the exchange motor program.
At the moment I am not sure if I want to replicate this as part of my Intake Refresh renewing, and cut a perfectly good brand new hose in half for an unknown function that most likely I will never use...
Ive seen it on a good number of cars and just replace the hose w/o the fitting when doing an intake refresh. Only use I could ever think of was a test port for checking intake vacuum or a 1/2 asssed way to leaving something for additional plumbing for ventilation.
That is very interesting, Åke, that such an earlier car has it too - thanks for sharing that fact.
Received 1,543 Likes
First time I saw it I ‘blamed’ it on the technician, previous (TP). The second time I wondered how TP got around from coast-to-coast. The third time... must be Hans und Franz.
Basic Site Sponsor
Basic Site Sponsor
Fairly common on late model engines. Complete mystery regarding function.
I've never considered that they might be only on factory rebuilt engines.
I'll pay more attention to model year and engine number.
I, also, replace with the one piece hose, if that hose needs to be replaced.
Basic Site Sponsor
Basic Site Sponsor
Since that hose is a combination of intake manifold vacuum and crankcase pressure (with a restrictor), I'm guessing that data gathered over a long period of testing new engines would give Porsche an indication of how well each engine performs.
.....An engine with poor cylinder sealing would have a different vacuum/pressure reading on that hose than an engine with perfect cylinder sealing, right?
