Window Motor Help Please
Hi Guys,
On the 79 I have twelve volts at the motor when the switch is activated but the motor won't move. Is there something internal that can be replaced or looked as the culprit?
Cheers
Scott
Cheers
Scott
The window motors can be removed from the regulator assembly and taken apart. The brushes for the motor can get frozen in place by corrosion.
https://rennlist.com/forums/diy-928/466375-how-to-repair-928-window-motors.html
Team Owner
Team Owner
Speed yes it could ,
the memory/relay board under the seat does well if its resoldered
