Belt Tool
Belt Tool
What the hell is the deal with that timing belt tensioning tool for $500+? Is this really necessary or can I just use the $59 aftermarket tool? Wow! Has anyone used either of these?
Joey
Joey
I've used both. The $59.00 deal works fine. It just doesn't let you set the alternator belt tension (newer cars).
That I can live with.
FYI- The $$ tool is just under $400, not $500.
Re: Belt Tool
Get $59 Kempf tool. Mine was recently tested agaist factory tool and it was spot on and much easier to get same results every time. Factory tool gave about 0.1 different number on two consecutive measurings depending on minor difference how it was held. It's way too complex for the job. Too many parts that can break even though it's very sturdy.
Regards,
Erkka
1992 928 GTS 5-speed very lose belt
Oak Green Metallic 22L
Classic Gray MX
Regards,
Erkka
Classic Gray MX
Inventor
It's not science... the tension just has to be "in the zone".
The tension is going to change +/- with age, temperature, etc., anyway.
Range Master
Pepsie Lite
Pepsie Lite
'nuther vote for the Jay Kempf tool. shuddah come in the stock tool kit from Porsche.
