best all around wire crimper?
Looking for a crimper set that will do proper crimps in aprox 16 down to 4 ga & at reasonable cost $75 or less . I'm aware of many high priced alternatives but don't use them enough to justify .What are you using? Source?
Thank you for your replies
i bought my wire stripper and crimper at Home Depot. I believe they are both Klein Tools. Makes short work of automotive wiring projects.
There are several that allow you to swap the jaws out so you can crimp the size range you are looking for. Here is one at Summit Racing, there are others other there and most under $80.
https://www.summitracing.com/parts/b...4aAle6EALw_wcB
