Mystery high pitch squeal
Your query reminds me of a very similar issue I experienced a few years back now, every now and then the car would issue this high pitched shrill whistle sound, similar to a spun bearing sound / or a fast rotating steel wheel rubbing on some metal, then it would just go as quickly as it came.
Mine too seemed to be coming from the centre to bulkhead area.
We never sourced where the noise was coming from exactly, safe to say a few weeks later the air-con compressor failed ie, completely burned out. After that was replaced we never ever got that noise again .
Ken
80 928 S
5 Speed
UK
Ken
80 928 S
5 Speed
UK
Fred
Fred, Last night I looked at the wiring on the console I'm reinstalling and on the motor I just cleaned before re-installing it.
The motor has two wires White w/ Red and a brown, it unplugs directly at the base of the motor (if you can get to it).
The same two wires go to a 4 pin that has two yellow wires for the inside temp sensor and the two for the motor, that connector is behind the HVAC, and that may also be a good spot to disco the motor, however the sensor needs to stay connected.
I'll post up some pics later today when I get them off my phone
Dave
Dave
Dave
Dave
You are a star!
Dave
Dave
Took the 928 for a nice ride this afternoon. Whilst out the issue took a new turn in that it started to squeal continuously. Gave the dash a thump over the top of the air intake thingy and the noise stopped. I think I can safely say I now know what the issue is!
Hi Fred, here are some pic's of the motor (removed from the housing and the 4 wire and also the 2 wire (orange) that go to the center vent micro switch.
They are both hanging down together in the center and attached via hold-down to the HVAC unit, so you should find them in the same place.
Hope that helps, and yes the center con will need to be removed to replace that motor
Also I used on of Nat's printed vent tops in my console and it worked GREAT!
Dave K
Dave,
Any idea how many thumps the dash panel can handle before it deforms?
Many thanks for the pics and the input. Sooner or later I am going to have to pull the dash and have a crack at the HVAC issues- that or rip the job lot out and put a fixed switch on the blower and run the a/c with an on/off switch!
Well the problem has gone from an occasional squeal when I go over a bump to a continuous squeal when I go over a bump and no amount of thumping the dash panel will stop it- urrgh!
Absolutely no doubt what the cause of the problem is- well done Dave! I would never have found that one I suspect especially as I did not know there was a motor in there. Tomorrow all being well I will pull the side panel and see if I can find connector 31 with the two yellow cores, a red/white and a brown cable. The red/white is the power supply to the motor and the brown the earth. If I can disconnect the red/white [or the earth] that should silence the thing. As I do not use the temperature controller feature that should not cause any issues or so I would think].
Some time later, being somewhat concerned about what I perceived to be a lack of performance, my good friend the local service manager took the car for a test drive with me in the passenger seat- that convinced me there was nothing wrong with the car! It is one thing when you are in control of something you are used to but quite another when sat in the passenger seat watching the world hurling towards you at warp speed! It really was an unreal experience- makes me wonder if I am the only one like that or whether others experience the same sensation. Either way I take it steady with passengers in the car unless they ask to "give it some welly".
Today I removed the passenger side access panel to see if I could locate the power supply to the suspect motor. I was hoping to find connector 31 but could not trace it. I managed to locate connector 29 and pin 4 of this connector is the cable that forms pin 2 of connector 31 but that cable disappears behind the bulkhead as it presumably approaches connector 31 but I could not get my hands on this- urgh! The only other thing I can think of is to trace the earth connection for the motor. There are some 6 cables going to earth at the same point- appreciate if anyone can give me a clue as to where this earth point is located. That or I will have to trace back from a known point such as the earth cable from the solenoid valve array for the actuators.
Dash panel squeal- Solved?
I think I cracked the basic problem this afternoon. I decided to remove the HVAC control unit just to see what I could see. Lo and behold the connector I could not locate was sandwiched between the frame and the unit. Followed the cables and found the connector on the base of the motor so disconnected the fan motor. Hopefully that will cure the squeal. I am assuming I do not really need that fan to work - hopefully it will not toast the temperature sensor. I do not use the control that selects cabin temperature- during the hot season I need maximum cooling and if it gets a bit chilly, as it can, I simply turn down the blower a notch.
