VIN decoder
Mark: it's in the WSM. I thought it was on 928s4vr.com, but that site has been up and down. If is is working, there is a lot stuff you will want to print. Knowing that you are "buying," it sounds like you need the "specs" option codes and paint codes at 928gt.com. There is a chart on engines and transmissions, etc. by year that is very useful. And you will want to print a copy of the relay chart.
VIN codes, engine codes, transmission codes and Option Codes are all on PET too.
When you have selected a car model, and then year, you can select the "Function" tab and select which decoder you need.
