I have reached a stand still in my HVAC repairs
I have been working to repair my vacuum controlled A/C pods. I am currently working on the pod on the center consol. Apperantly I did not order everything I needed for this job.
My questions is, what do I repair or replace this pod with, part numbers would be great.
second, my auto control cercuit board if burned up. I am going to try and fix it, but if someone has a used one they are parting out, I would be interested.
Thanks for any input, someday my AC will work correctly.
here is the only link I can find, and it was never updated on if it worked.
https://rennlist.com/forums/928-forum/742882-1982-hvac-center-flap-dual-diaphragm-vac-pod-replacement-from-roger.html
Contact Roger at 928sRus for the parts you need.
Have you searched for either Dwayne or Wally's HVAC procedures? They're both hosted off of Rennlist, but will give you all you need to know. Long story short, you're only replacing the rubber diaphragm in that pod. Roger sells 'em.
I will also try and find the hosted forums on the subject.
Ok,
I have talked with Roger. This part is NLA and he has no parts to repair it. But, Roger did give me some tips to repair the old rubber. Thank Roger.
Now to tackle the circuit board issue.
