Snap - Broken e-brake cable on the passenger side. easy fix? what parts needed?
anyone replace the entire or parial ebrake cable, I pulled on it and went "Snap". it broke near the passenger side hub, but after looking at the mechanism i dont know how it all joins together and what needs to be replaced if i am to fix it. i do use it at the track and on the street. most of the racers ditch all the e-brake stuff, but i still use it and if the repair is easy , i might take it on.
thanks,
Mk
thanks,
Mk
Archive Gatekeeper
The passenger side half is the 'main' portion of the ebrake cable, $50 used, from 928Intl.
http://shop.928intl.com/Used-Right-B...28-424-552-16/
Ordering tomorrow!
thanks again Rob!
Archive Gatekeeper
There's a pin and a circlip that hold the two halves of the cable together, you'll want to save the pin from your current brake cable. Or just buy a whole e-brake cable from Anderson, and save yourself the hassle of the other side breaking soon..
You'll have to undo the cable at the handle (14 mm nut, with a 7mm wrench to hold the flats on the cable) , pull it out of the tube through the floor of the rear seat, unbolt it from the crossmember.
Then you have to pull the caliper, the rotor, and the e-brake shoes to be able to undo the cable end from the adjuster. There are some good pictures in another thread from today:
https://rennlist.com/forums/928-foru...uspension.html
Another good thread on e-brake pad and mechanism R&R: https://rennlist.com/forums/928-foru...d-springs.html
Chronic Tool Dropper
Mark--
In Rob's latest picture, the two tabs at the bottom are bolted through the crossmember so stay the same distance apart. As it's laying on the floor in his picture, you are looking at the cables from the rear on the car. The driver's side cable is on the left, and the end of that connects to the tab immediately above it. Pull on the main passenger side cable draws the tab and the connected end towards the passenger side, pulling the drivers side cable out at the same time.
i got it all installed. (Thanks for the pics!!) BUT, (UGGGG ) , the cable housing on the passenger side is TOO short! doesnt mate to the hub!!!! maybe its because i have a 86 chassis and suspension and the cable i tried to install is out of an S4? my car is an S4, but if you remember, we bolted on the Holbert car's running gear and suspension.
is the S4 e-brake cable at the passenger side, about 6" shorter?
Archive Gatekeeper
All the parking brake cable components are the same, 78 to 95. Got a pic of what's wrong?
from the pic, you can see that section aligned up with the new cable (too short) mounted to the car
the next pic shows it going well past the hub , about 6" and allows for the end of the cable housing to fit into the hub housing securely.
thoughts???
see you in a couple of weeks! i owe you !
Mk
Archive Gatekeeper
Yeah, those tubes are kind of essential. Glad you found it and were able to get it out of the hub, they often corrode in-place.
im still reluctant to toss out the remainder.
im like the only car in the paddock that has a e-brake... but since i drive it on the street and sometimes it comes in handy, like on the trailer.....so, im keeping it in.
