928 Forum 1978-1995
Sponsored by: 928 Specialists
Instrument cluster "@*^&! CR**
Old 12-02-2017, 06:13 PM
Geo55
Geo55's Avatar
Default Instrument cluster "@*^&! CR**
I cant believe that I just dropped my instrument cluster. Broke the speedometer needle off , and bent the voltmeter .Crap!! So Is it true that you have to have the thing programmed to your car? I read that on an ebay auction. And I just replaced the odometer gear too!
Old 12-02-2017, 06:37 PM
SeanR
SeanR's Avatar
There is no programming on those so don't worry about that portion.
You can send your speedo off to Palo Alto speedometer and have it fixed, or get one from 928 International.
Old 12-02-2017, 06:40 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Give Mark Anderson, at 928 International, a call Monday, George. He'll tell you the truth, and probably has what you need to repair or replace yours. His Holiday Sale is on, and all used parts are 50% off.
Old 12-02-2017, 06:49 PM
Geo55
Geo55's Avatar
Thanks guys, I cant believe I did this!! If my feet faced the other way I'd kick myself right in the ..........
Old 12-02-2017, 07:04 PM
GT6ixer
GT6ixer's Avatar
That sucks. You can also contact Buz Ras at Seattle Speedometer. I had a broken speedo needle and he found me a spare for a reasonable price.
http://seattlespeedometer.com/
Old 12-02-2017, 10:39 PM
PaulD_944S2
PaulD_944S2's Avatar
Go on eBay and buy a cheap gauge cluster and use the needle(s) from it to fix yours.
Can be any of several different models, not necessarily a 928.
Old 12-02-2017, 10:57 PM
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
At least you only have yourself to blame,
When I had my cluster out to replace the odo gear, I played it smart by doing it in the living room on a clean table, ...after a quick break before reassembling, I can't find the speedometer needle.
....I forgot I have cats..
Luckily I found a complete cluster on fleabay for only $140, ....all I needed was the speedometer needle.
that was one expensive cat toy.
Old 12-02-2017, 11:00 PM
Geo55
Geo55's Avatar
Paul, the shaft broke/ snapped off also, along with the needle was crushed. Are you saying that the speedos are the same from say a 924? We have one at our local Pick-a-Part.
Old 12-02-2017, 11:43 PM
Randy V
Randy V's Avatar
Shyte happens.
Old 12-02-2017, 11:52 PM
OTR18WHEELER
Originally Posted by Randy V
Randy happens.
FIFY
Old 12-03-2017, 10:49 AM
Wisconsin Joe
Wisconsin Joe's Avatar
You can take a look, but I think the 924 & early 944 has a significantly different cluster. Later 944s have a very similar one.
Old 12-04-2017, 11:16 AM
bureau13
bureau13's Avatar
One of my cats stole the intensive washer button, and almost got away with that little metal part that is part of the pod-mounting hardware. Fortunately I found that one...
Old 12-04-2017, 12:16 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
I have an 87 cluster with individual parts you need if Mark cannot help you out.
Old 12-04-2017, 01:12 PM
RennPartsDirect
Former Vendor
RennPartsDirect's Avatar
I have all of the gauges from my 86 manual if you need donors...
Old 12-05-2017, 05:06 PM
Geo55
Geo55's Avatar
Thanks so much guys. I am working on some parts form the boneyard. If that falls through then I will call Mark. I think I'll be OK. I appreciate the offers.
Quick Reply: Instrument cluster "@*^&! CR**
