928 Forum 1978-1995
Sponsored by: 928 Specialists
What is your winter project?
Old 12-08-2003, 07:15 PM
  #46
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
Gonna install Tim Murphy's S/C kit on Gretch. Already did the short shifter and am in the middle of replacing the clock (digital to analog).
Old 12-08-2003, 10:24 PM
  #47
GoRideSno
GoRideSno's Avatar
Finishing up the manufacturing of my SC parts so Mike, Doz, CMW and a few others can get started on theirs.
Andy K
Old 12-09-2003, 12:15 PM
  #48
Mark
Mark's Avatar
Getting the track car project done!
-finish stripping crap off
-sand/paint
Install:
--85 EURO engine
--Eibach/Konis on all 4 corners
--brake upgrade
--steering rack
RUN THE CRAP OUT OF IT!
Old 12-13-2003, 11:21 PM
  #49
Glenn M
Glenn M's Avatar
1. Adjust timing belt.
2. Replace MAF.
3. Install Nology wires.
4. Check ride height and adjust if needed.
5. Fix vacuum leaks.
6. Paint GTS wheels and replace rear tires
7. Check for torque tube play.
8. Replace motor mounts.
9. Replace oil pan gasket and install GTS baffle.
10. Replace fuel filter.
11. Fix paint chips.
12. Troubleshoot heated seats
Triumph Stag
13. Repair head (spark plug insert blew out).
14. Flush cooling system.
15. Stay out of the dog house for working too much on the cars!
Old 12-14-2003, 09:41 AM
  #50
Fastest928
Fastest928's Avatar
600 rwhp.
Marc
DEVEK
Old 12-14-2003, 11:42 AM
  #51
Mike LaBranche
Mike LaBranche's Avatar
Well, now that it _is_ winter, guess it's time to get to work on the beasts.
'78 OB:
tbelt retension, new AC dryer/evap, replace rear muffler (original fell off at PA turnpike gas stop), better glue for hood insulation, fresh axle boots, window roller kits.
'84 S:
tbelt retension, TC bearings/seals.
'99 ZRX1100:
2mm overbore, forged 12:1 pistons, install Cope Racing head, time cams.
Dodged a maintenance bullet yesterday. I was contemplating a 78 Euro 5spd for $2k locally. Guy brought it over to 'do the deal'. Car was a mess. Poor repaint. Interior trashed, full of acorns and parts. Engine started. Eventually. Valves all a clatter. Then proceeded to leak fuel at the accumulator, filter, pump, tank. Pump was held in place with zip ties. Fuse/relay panel laying on pass. floor. Didn't take long to figure that this example had nightmare potential. I could certainly rescue it and bring it back to life but it would have been $5k and 6 months of every weekend. No thanks.
Happy wrenching, all....
Old 12-15-2003, 09:29 PM
  #52
Glen McCartney
Glen McCartney's Avatar
8" headlights
New lower ball joints
New tie rods
Bilstein/Eibach upgrade
Considering powder coat intake and cam covers, replacing all rubber under intake, send injectors out for calibration, BUT, the beast is running great and I'm not sure I want to mess with this just now.
Old 03-11-2004, 04:49 PM
  #53
Shane E.
Shane E.'s Avatar
Well is everybody going to meet their goals for this winter? Mine got tossed right out the window. Descided just to do a thorough tech/prep of Heidi and take her to SRP for a day of stretching her legs. The rest will have to wait till fall when I will have a full winter to work with.
18 days and counting!
Old 03-11-2004, 05:10 PM
  #54
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
By now, everyone here is sick of my reporting on the progress of my project, so let me just say that it is finished.
Old 03-11-2004, 07:12 PM
  #55
Shane E.
Shane E.'s Avatar
Jealous maybe but not sick! We all love to here about your install and to see your pics. We are all waiting in antisipation for your dyno results!!
Old 03-11-2004, 09:08 PM
  #56
heinrich
928 Collector
heinrich's Avatar
Shane you've got a pretty sweet project coming up Brother.
Old 03-11-2004, 09:23 PM
  #57
zmandan
zmandan's Avatar
After 3 mos at dealer and 10K spent Iam now down to the little things.
replace burned out fog lite
install window wedge
install new 1/4 window trim
instal decals at rear ( lite gray hope they match wheels )
paint wheels
replace wiper motor cover ( got beat up by wiper linkage )
install sound proofing to lower road noise
replace front and cargo carpet
remove bracket that holds POs mobil phone and install cup holder(s)
upgrade sound system
install new ***** at door(s) compartment
improve alignment of hood, doors, hatch etc
and I might replace hood insulation
and of course clean grounds
I hope to have work done by mid april
dan z
Old 03-11-2004, 09:34 PM
  #58
Shane E.
Shane E.'s Avatar
I have actually got two! The installation of Bobs' interior into Helmut (man is that going to look sharp or what) and a secret one that will probably become obvious at SRP. And of course a bunch of smaller ones too. Like getting the H4's mounted, getting the V1 mounted and wired, steering wheels mounted, and still got to get an Ott test pipe.
Old 03-11-2004, 09:46 PM
  #59
Paul D
Paul D's Avatar
I'll be taking a crusty S4 suspension and brakes and completely refinishing them. New brake lines, lower ball joints, rotors, wheel bearings, piston seals, etc... Can't wait to stomp on these puppies at the end of the front straight at Watkins Glen! Here is a before shot:
Quick Reply: What is your winter project?
