Blue smoke....
Blue smoke....
Hi guys,
So got the car out for a sunny evening drive, started fine as usual having sat for a month. Slight smell of oil on start up but no smoke. Drove ~2 miles before large blue smoke cloud emanating from the exhaust. Oil pressure fine, temp fine ran ok at first then a bit rough. Stuck it back in the garage and haven't had time to check anything other than Clarkes garage and Renlist threads. Where do I start?
82 944 NA, 80k miles, running VR1 oil
Just a possibility here, because this is a common issue with 944s... but if you have a leaky cam tower gasket, like I had, it takes a while for the oil to start leaking out, but when it does and hits the exhaust manifold, you get lots of blue smoke. Just a possibility.
Hi Schmooey
Had a look but it doesn't seem to be that. All the oil smoke comes from the exhaust. I am thinking compression/leak down test as a first step
Regards
D
Regards
D
UPDATE...
So had a look this morning. Dipstick shows water in the oil so suspect head gasket failure. Funny that it only seemed to be oil in the exhaust, not steam. Wondering how to differentiate between head gasket failure and oil cooler - typically my compression tester is 300 miles away while we are away over the summer...
David
David
I am a dope..
Plugs oily not steam cleaned....but only checked these after I removed the head. Sure the HG is in a poor state (probably original 1982 vintage) but the flame rings have not been breached. Finger of suspicion points now at the oil cooler/seals. Gasket has been replaced with the more recent green/combined type at some point but haven't managed to get the cooler out yet to fully examine/measure etc. Thinking I will get it pressure tested. What an PITA removing it is.. Still nowhere near as bad as removing the sump on a 928 though...
