What's correct Head Stud measurement from block?
Old 07-01-2017, 12:54 PM
Todd951968
Todd951968's Avatar
Default What's correct Head Stud measurement from block?
I suspect my head studs are screwed too deeply into the block, no not allowing the nuts to be fully fastened onto the studs (there are jut threads exposed so maybe they are on about 3/4 of the way?)
I bought the car not running and the PO attempted 2 head gasket replacements that failed so he gave up. Not sure if he messed with the studs in the first place...
What is the correct measurement of the stud when inserted into the block, from the block deck to the tip of the stud where the threads are?
Old 07-01-2017, 03:04 PM
951and944S
951and944S's Avatar
Which engine...?
16V and 8V are different.
I might have pics of height on an 8V.
T
Old 07-01-2017, 03:53 PM
Todd951968
Todd951968's Avatar
Thanks, its a 2.5L 8V from 1987 924S
Old 07-01-2017, 08:29 PM
Tiger03447
Tiger03447's Avatar
See if Morghen can help. Seems to know his way around 924's pretty good
Old 07-01-2017, 11:16 PM
951and944S
951and944S's Avatar
Sorry, might have over promised. Pic is too blurry to see, looks like 71mm but wouldn't swear by it.
I can measure one in the morning for you though.
Alternatively, if you have a head off, just depth measure from the nut/washer land to a flat surface, add 1.5mm for head gasket plus the thickness of a head nut/washer.
T
Old 07-02-2017, 12:40 AM
V2Rocket
Rainman
V2Rocket's Avatar
Spec is 72mm but there is tolerance
Thread height over the nut doesn't really matter as long as the full nut has threads engaged
You should get the head surfaced before reassembling.
Old 07-02-2017, 01:25 AM
edalenta
edalenta's Avatar
"Alternatively, if you have a head off, just depth measure from the nut/washer land to a flat surface, add 1.5mm for head gasket plus the thickness of a head nut/washer."
This is what I did (87 924S 2.5L NA) and RaceWare concurred. You also want to account for 2-3 full threads past the top of the nut.
Old 07-02-2017, 08:04 AM
Todd951968
Todd951968's Avatar
Mine were all 2 full threads BELOW the nut before I took the head off! I checked my studs with a tape measure (I know, I will now take a more accurate measurement) and they were all in the 66mm range.
How do I back out the studs?
Old 07-02-2017, 11:55 PM
PaulStewart
PaulStewart's Avatar
Place 2 nuts on the stud, use the lower one to back out the stud, or use a stud puller.
Old 07-03-2017, 01:41 PM
GPA951s
GPA951s's Avatar
3" from the Deck of the block. is what I go by.
Old 07-03-2017, 04:31 PM
Van
Van's Avatar
The 72mm is for an 8-valve, the 94mm is for a 16-valve.
Old 07-03-2017, 05:06 PM
951and944S
951and944S's Avatar
I would have looked up the data before I replaced mine in the photo above but I can’t remember where it came from....., was that from a supplement or the original manuals...?
Anyways, 71.76mm is reading on my digital calliper, I missed that one by ,24mm, or 20 thousandths....
T
Old 07-04-2017, 09:22 AM
Todd951968
Todd951968's Avatar
Thanks for the info! Mine are all well below that. Is it OK to just back them out a bit to meet spec or do I need to take them totally out and put loctite on the threads?
Old 07-04-2017, 10:17 AM
951and944S
951and944S's Avatar
Why someone would have had them in beyond spec height is the concern.
Hopefully it's not the case - but you know for sure they were removed before because they are installed wrong - that the person who worked on it set that height in search of good threads.
I think I would take this opportunity to remove them, run the proper tap (you want a "blind" tap not a conventional thread tap), clean the bores/threads with a solvent and compressed air, then, when you are ready to install, make a measurement from the deck to the top of the stud with each stud just resting on the first thread to to insure that you have adequate good threads once they are installed at correct height.
Resting in the bore, before 1st thread is engaged, you should have at a minimum, 72mm + the diameter of the stud, Twice diameter is probably closer to factory thread engagement.
I use a Loctite/Permatex brand liquid teflon on those threads but I only use aftermarket studs with the hex drive feature to turn them. I have never had one turn when torquing head but in the event you did, an allen wrench can hold it.
T
Old 07-04-2017, 04:08 PM
500's Avatar
Interestingly, the 944S 16V stays with the same 72 mm stud height as the 8V cars. I know the 94 mm is correct for the 968, but I don't know about the S2.
I just went through this exercise on my 2.5 16V rebuild for which I installed new factory head studs. The result with the head on looks perfect, with just a couple of threads visible past the top of each nut with everything torqued to spec. Originally I had that same page from the 968 workshop manual and I was expecting a 94 mm height...
Not helpful for the OP, but just putting this here in case someone with a 2.5 16V is searching this question in the future.
Thanks!
Quick Reply: What's correct Head Stud measurement from block?
