Loud clunk when turning engine over
A automobile that its engine doesn't clunk when turning over.
You do know this is a Porsche forum?
Anyhow, did you try turning the engine over with a breaker bar? The rings may be stuck from years of sitting. If it is stuck, pull the spark plugs and shoot Marvel Mystery oil into the cylinders. Let it sit a few days and try again to turn over with a breaker bar.
wrong place lol
lol...i just google my issue and came to this...didnt say anything about porsche..and thanks for the info...it does turn over tho...............
if it hasn't run in a while i wonder if a connecting rod is "loose" without any oil underneath the bearing.
that could make a clunk. but spinning it over with the starter enough should make oil pressure on your V6.
Torque converter bolts tight? They may be hitting the back of the block.
Did you try cranking without the serpentine belt? Could be a locked Alternator.
Do you know why it's been off the road?
