Need an engine shop to do an overbore - SE Michigan
#46
Just a car guy
Pulled one head stud out. It came out surprisingly easy. I figured - oh boy, this might not be so bad.
Tried a few more. Let's just say I got real lucky on the first one.
Broke two waterpump studs off. The others came out. Got no movement on the M8 studs.
I am curious if the studs, removed by 928Motorsport will be returned and also be reusable? I don't think I can go much further beyond what's been removed to this point. It's about time to package it up -- tips on how to best do this are also appreciated - and ship it.
#47
Developer
Yes, I can return to you whatever we remove.
If you do not have the right tools to remove the head studs, I implore you to stop before damage is done. Let us remove the head studs and charge you for our time. Way cheaper that trying to fix a damaged block.
944 blocks are easy to ship, just double box it and pack it well. Put some crushable material in each of the corners in case it is dropped. Ship by Fed Ex to get better handling, UPS if you must. Insure it for its full value.
#48
I'm pretty sure the water pump studs NEVER come out without breaking off or screwing up the hole. When I pulled mine the threads in the block had been transformed via corrosion into this weird black crud. I made a simple drill fixture and drilled out and Time-serted all the threads for the water pump and oil cooler. No way was about to mess with the head and main studs. Better to Carl and his guys wrestle with those!
#49
Just a car guy
Sounds good. Hopefully I'll have a chance to package everything up over the long weekend. It seems my time is in very short supply.
#50
Developer
We use an Oxy-acetylene torch to warm the area of the block holding the lower threads as they have a Loctite-red type thread locker on them that requires heat to release. Then we use a collet-style stud remover to remove the stud without damage. Using two nuts can damage the threads and over-elongate the fastener.
Attempting to remove the studs without softening the thread locker resin with heat can cause damage to the threads in the block.
There are other little tips and tricks too - but that's the most of it.
#51
Just a car guy
Yes - I used a torch to heat things up. I did not like the idea of putting two nuts together after messing with it for a while. Somehow the first stud came out even without heat.
#52
This is a great thread with awesome info!! Learning lots!
However I'm now scared of re-ringing my 87.... Going to have to do a lot more research.
Thanks Scott and Carl for taking us along for the ride! Great stuff.
#55
Just a car guy
It's on the way. Shipped out Friday. The people at FedEx didn't like my packaging, so they put the lump in one of their boxes. Evidently fiber reinforced packaging tape doesn't match their definition of packaging tape.
I scrounged up just about every piece of cardboard I had to pack it. Don't feel obliged to return it all...
#56
That looks like it might not protect the block that we'll. I hope I'm wrong! I sent mine in one of those Pelican-type cases. You can get them used on E-Bay.
#57
Rainman
Scott - the shipping companies very much prefer the clear plastic tape because it actually has a higher tensile strength and sticks harder than the paper tape with water-activated adhesive.
Hopefully the box they put your block in is sturdy - those studs like to poke out any way they can...
#58
Just a car guy
What's up with the murdering psycho that is always in your avatar? Do you have a thing for this?
Studs were backed by at least four thick layers of cardboard. Putting it all in another box was no big deal - a little more protection is fine. What really bugged me was the argument that my tape was "not even packaging tape".
Whatever...
#59
I'd rethink that packing strategy it killed more than few blocks. When delivery guys drop it from truck to the ground and it hits the corner, it's gone.
Happens on head studs too..
