Valve springs
Rainman
turbo springs are "stiffer" to deal with the added boost pressure acting against them.
in an NA car that lends a little more high rpm capacity/stability for an aggressive cam.
they can wear out and lose some springyness but luckily they are cheap brand new still.
Okay...
Thanks guys.
I *think* MM mentioned that he's never seen a stock set of 16v springs wear out. So I thought I'd enquire about the 8v. For my uses I'll save the bucks & fork out for turbo ones. Are 951 engines fine with with 15lbs of boost and mild cam?
Thanks guys.
Rainman
15lbs + cam yes just keep the rpm down (stock redline or lower)
the spring wants to keep the valve closed.
boost pressure in the intake manifold wants to push the valve open (or keep it open if the camshaft has opened the valve already).
so cam pressure + boost pressure pushing down on the valve needs more spring power to pull it back closed.
