Nord Lock Locking Washers
Just curious if anyone has tried these Nord Lock washers instead of the Stage 8 for the CV axle bolts?
I'm also interested in these, they seem like the best solution I've seen so far. Waste gate hardware too. I'm going to order some from my local supplier and give them a try.
Good to hear they have users with positive results. I saw them at Walmart $15 for 20 in M8 size, probably also have to buy longer bolts though to account for the washer thickness.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1000x752/img_2363_5211d328b33b01eb312b387625dadeb44978048c.png)
I use schnoor washers now, solved my loosening problems at the CVs.
Rich
Rich
Last edited by rlets; 12-21-2016 at 11:53 PM. Reason: I originally said nord lock, but meant schnoor.
I too have these on my axles. Completely solved my constantly loosening CV cage bolts. Definitely worth the cost. I also replaced the 12pt cheese head with conventional Allen heads I picked both the bolts and nordlocks up at my local fastenal dealer.
Schnoor were conical spring washers with ridges which relied on pressure and friction to lock in place. Not the same as Noor which rely on the relationship of the angle of the ridges to the angle of the screw thread. IIRC factory mainly used Schnoor washers to stop trim vibrating loose. I seem to recall dropping them when I've taken interior panels off.
